No subject
    Mon Oct  7 05:54:23 PDT 2024
suggested that SegFault problem could be traced to mapserver's shp2img,
so we tried shp2img and did get that segfault crash. When we tried using
gdb to 'debug' the shp2img util with the same mapfile, we found it
crashed on tif_read, here is the message before it died,
(gdb) run -m /var/www/html/zoom2it_mapserver/map_file/test_wms.map
Starting program: /root/build/mapserver-4.0.1/shp2img
-m/var/www/html/zoom2it_mapserver/map_file/test_wms.map
(no debugging symbols found)...
(no debugging symbols found)...[Thread debugging using
libthread_dbenabled] [New Thread -1084655424 (LWP 5180)] Program
received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1084655424 (LWP 5180)]0x00a036ad in TIFFFillStrip
(tif=3D0x8863628, strip=3D1) at tif_read.c:252252 bytecount =3D
td->td_stripbytecount[strip];
I hope i have explained my problem clearly. Any help/hint will be
greatly appreciated! By the way, almost all mapserver versions above
4.0.1 have been triedwith the same configs as below and failed exactly
the same way.
Here is my mapserver config:
MapServer version 4.0.1 OUTPUT=3DPNG OUTPUT=3DJPEG OUTPUT=3DWBMP
OUTPUT=3DPDFOUTPUT=3DSWF SUPPORTS=3DPROJ SUPPORTS=3DFREETYPE
SUPPORTS=3DWMS_SERVERSUPPORTS=3DWMS_CLIENT SUPPORTS=3DWFS_SERVER
SUPPORTS=3DWFS_CLIENT INPUT=3DJPEGINPUT=3DPOSTGIS INPUT=3DOGR =
INPUT=3DGDAL
INPUT=3DSHAPEFILE
And here is the wms map file:(without vector layers)
MAP
        NAME DURHAM_WMS_TEST
        SIZE 490 440
        STATUS ON
        EXTENT 523522 4824701 712474 4963303  #simcoe
        UNITS METERS
        SHAPEPATH "/var/www/data/zoom2it_mapserver/"
        FONTSET "/var/www/html/zoom2it_mapserver/map_symbols/fonts.txt"
        SYMBOLSET
"/var/www/html/zoom2it_mapserver/map_symbols/symbols.sym"
        IMAGECOLOR 255 255 255
        IMAGETYPE  PNG24
        PROJECTION
                "init=3DEPSG:26917"
        END
        # NOT WORKING
        #OUTPUTFORMAT #not sure if this is really necessary
        #       NAME GTiff
        #       DRIVER "GDAL/GTiff"
        #       MIMETYPE "image/tiff"
        #       IMAGEMODE RGB
        #       EXTENSION "tif"
        #       #TRANSPARENT FALSE
        #END
        WEB
                MINSCALE 1500
                MAXSCALE 700001
                TEMPLATE durham_data_wms.html
                IMAGEPATH "/var/www/html/zoom2it_mapserver/map_images/"
                IMAGEURL "map_images/"
                METADATA
                        WMS_TITLE "durham data served via wms"
                        WMS_ABSTRACT "WMS server compliant data service
for durham area"
                        WMS_ACCESSCONSTRAINTS none
                        WMS_ONLINERESOURCE
"http://pc82.jdbarnes.com/cgi-bin/wms_map"
                        WMS_SRS "EPSG:26917"
                END
        END
        #LAYER DEFINITIONS ---------------------------------------------
        LAYER # testing tiff
                NAME durham_tile
                STATUS ON
                DATA
/var/www/data/zoom2it_mapserver/256/simcoe_10k_6m/ORTH175640485302002FBS
.tif"
                TYPE RASTER
                METADATA
                        WMS_TITLE "Durham Ortho Photo(50cm - Tile)"
                        WMS_ABSTRACT "ortho_lro_40_50cm_wms test tile"
                        #WMS_SRS "epsg:26917"
                END
                PROJECTION
                        "init=3DEPSG:26917"
                END
        END
END
More information about the MapServer-users
