No subject
Mon Oct 7 05:54:23 PDT 2024
c:\......\mapserve.exe
See if it produces error messages. If it does then you need to place
all the mapserver dll's into your windows\system32\ folder or else
make sure that the location where you have them is listed in the PATH
environmental variable.
Cheers,
Ken Lord
Vancouver BC
On Thu, 24 Feb 2005 13:04:02 -0600, V P <vprak at appsci.com> wrote:
> Thanks. Your solution worked. My problem now is, when I hit
> the 'Initialize' button it spits out a dialog box stating..
> Mapserv.exe - App Error
> The instruction at '0x77f88216' referenced memory at '0x00000010'. The
> memory could not be 'written'. Click on Ok to terminate or Cancel to debug.
> After I hit okay, I get the
> 'CGI error message.'The specified CGI application misbehaved by not
> returning a complete set of HTTP headers. The headers it did return are:
> I'm not sure what this problem is now. could it have something to do with
> the /tmp file?.. or where it's trying to write to? I set the security of
> the tmp folder for anonymous users to read/write.. etc. I'm stumped once
> again. Could someone help? Thanks.
More information about the MapServer-users
