No subject
Mon Oct 7 05:54:23 PDT 2024
display in mapserver.
layer
GROUP slp
NAME something
DEBUG ON
DATA ak2s
TYPE LINE
STATUS ON
class
color 200 200 0
end
end
layer
GROUP slp
NAME label_slp
DATA ak2s
LABELITEM elev
TYPE ANNOTATION
CLASS
LABEL
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
end
So, that is the basic hack. To do:
* allow the user to control the contour interval, color, ...
- allow variation of contours - dashed lines?
* control annotation the values 1004 vs 1004.000 (cleanup through PostGIS)
* properly identify the values -- its not just heights anymore...
Now you can contour any parameter you want: sea level pressure, heights,
temperature, .... or about anything gridded in the oceanographic
/meteorologic world. For all the weather winnies of the world...
Sample image: Sea level pressure map as produced from NCEP's
Global Forecast System on a 1/2 deg x 1/2 deg grid.
http://ak.aoos.org/mapserver/aoos/slp.png
If there is an easier way, please send it my way.
Happy Maphacking!
Rob
Rob Cermak : 907-474-7948 : FAX 907-474-7204 : PGP = 0x75869A6E
Alaska Ocean Observing System : Data Management
School of Fisheries and Ocean Sciences : University of Alaska Fairbanks
cermak at sfos.uaf.edu : fnjrc1 at uaf.edu
ED9U1M7P01 at alaska.edu : cermak at alaska.edu
More information about the MapServer-users
