No subject
Mon Oct 7 05:54:23 PDT 2024
not valid (but I might be wrong). Have you validated the geometry with the
validation procedure from Oracle? The sdo_geometry of 2003 suggests a single
polygon, but you Eleminfo does not. Try updating your sdo_geometry type to
2007 (multipolygon).
Hope this helps,
Gerjan
  _____
Van: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Namens
Francesco Sozzi
Verzonden: maandag 26 september 2005 12:09
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] problems with some Oracle polygons
Hi Fernando,
How are you?...
In some cases I have polygon defined with a code "5" instead of "1005". In
this case mapserver does not recognize the polygon format and it displayes
an error:
Warning: [MapServer Error]: msDrawShape(): Only polygon shapes can be drawn
using a POLYGON layer definition. in...
Here you are a sample polygon definition that gives me problems:
SDO_GEOMETRY(2003, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 5, 3, 1, 2, 1, 5, 2,
2, 13, 2, 1), SDO_ORDINATE_ARRAY(717393.311, 96290.2075, 717393.843,
96286.1065, 717300.032, 96279.4307, 717301.79, 96281.1715, 717303.764,
96282.6628, 717305.79, 96283.6852, 717307.995, 96284.2265, 717309.425,
96284.41, 717352.296, 96287.4608, 717387.403, 96289.9591, 717393.311,
96290.2075))
Any suggestions?...
Best regards
Francesco
------_=_NextPart_001_01C5C28F.D5B40830
Content-Type: text/html
Content-Transfer-Encoding: base64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==
------_=_NextPart_001_01C5C28F.D5B40830--
More information about the MapServer-users mailing list
