No subject
Mon Oct 7 05:54:23 PDT 2024
using driver `ODBC' successful.
1: PROPERTY_VIRTUAL
C:\Program Files\FWTools1.0.0a7>ogrinfo ODBC:parcel_test PROPERTY_VIRTUAL
INFO: Open of `ODBC:parcel_test'
Layer name: PROPERTY_VIRTUAL
Geometry: Unknown (any)
Feature Count: 1
Layer SRS WKT:
(unknown)
OBJECTID: Integer (10.0)
STATUS: String (20.0)
UTM_X: Real (0.0)
UTM_Y: Real (0.0)
AREA: Real (0.0)
SHAPE_Length: Real (0.0)
SHAPE_Area: Real (0.0)
HERITAGE: String (20.0)
PAR_UPDATE: String (10.0)
UPDATE_DATE: String (20.0)
CREATE_DATE: String (20.0)
UPDATE_SOURCE: String (50.0)
AREA_ACRE: Real (0.0)
PID: Integer (10.0)
AREA_HECTARE: Real (0.0)
OGRFeature(PROPERTY_VIRTUAL):0
OBJECTID (Integer) = 2
STATUS (String) = Active
UTM_X (Real) = 501405.687500125
UTM_Y (Real) = 4801949.24999883
AREA (Real) = 229.843703627485
SHAPE_Length (Real) = 77.3317483960398
SHAPE_Area (Real) = 229.843703627485
HERITAGE (String) = PART V
PAR_UPDATE (String) = (null)
UPDATE_DATE (String) = (null)
CREATE_DATE (String) = (null)
UPDATE_SOURCE (String) = (null)
AREA_ACRE (Real) = 0.0567943791663515
PID (Integer) = 42385
AREA_HECTARE (Real) = 0.0229843703627485
Any help would be greatly appreciated. I have several polygon layers to
publish this way, ultimately from an Oracle database.
Thanks in advance,
Mark Adams
Senior Analyst & Project Manager
Cuesta Systems (DPRA Canada)
5230 South Service Road
Burlington, ON L7L 5K2
Phone: 905-333-4544 x14
Fax: 905-333-0455
Email: mark.adams at dpra.com
On Wed, 21 Dec 2005 00:10:06 -0600, Frank Fica <simbiotico at HOTMAIL.COM>
wrote:
>Hello,
>I've been trying to map a non-spatial postgre table with ogr via ODBC but
no success. There must
>be a simple solution to what I'm missing and I haven't been able to
figure it out. My other layers
>do render but my Virtual layer doesn't. When I test in ogrinfo I can
connect but when I try to map
>in mapserver the image is blank, only my mapinfo layer renders.
>Does someone has any suggestions on what I'm missing?
>Here are is my ovf file:
><OGRVRTDataSource>
> <OGRVRTLayer name="sorento">
> <SrcDataSource>ODBC:@PostgreSQL,sorento</SrcDataSource>
> <SrcLayer>sorento</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="Lon" y="Lat"/>
> </OGRVRTLayer>
></OGRVRTDataSource>
>and map file:
>MAP
> IMAGETYPE PNG
> EXTENT -90.760314 14.252771 -90.210352 14.937117
> SIZE 640 480
> UNITS METERS
> SYMBOL
> NAME "circle"
> TYPE ELLIPSE
> POINTS
> 1 1
> END
> FILLED TRUE
> END
> LAYER
> NAME "ciudad"
> TYPE POLYGON
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "/var/www/html/guatemala/data/ciudad.tab"
> STYLEITEM "AUTO"
> CLASS
> NAME "Ciudad"
> END
> END
> LAYER
> NAME "sorento"
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "virtual.ovf"
> DATA "sorento"
> STATUS DEFAULT
> CLASS
> STYLE
> SYMBOL 'circle'
> SIZE 30
> COLOR 255 0 0
> END
> END
> END
>END
More information about the MapServer-users
