No subject
Mon Oct 7 05:54:23 PDT 2024
you need do little more than stick the string in as:
POLYGON (( 100000 100000, 200000 500000,500000 500000,500000 200000,
100000 100000))
(Or LINESTRING etc - Other Geom types detaild in second of the 2 links)
Best wishes
James
-----Original Message-----
Sent: 30 March 2006 19:09
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Defining a line from SQL server using
OGR
The x,y columns are doubles.  Where can I learn about geometry in WKT
format?
Thanks for all your help!
Chip
Chip,
what are the types of your gpsLongitude columns?  Are they array types
of some kind?  Or perhaps you are hoping that OGR will collect all the
rows, and make it into a single linestring features?
Basically, this is not supported.  If you could do something in the
database to prepare an appropriate line geometry in WKT format, you
could use the WKT column support in VRT.
Best regards,
--=20
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGF,
http://osgeo.org
More information about the MapServer-users mailing list
