No subject
Mon Oct 7 05:54:23 PDT 2024
=20
http://10.1.6.46/cgi-bin/mapserv?map=3D/home/earevalo/mapserver-4.8.3/tes=
ts/test.map&layer=3DTesting&mode=3Dmap =
<http://10.1.6.46/cgi-bin/mapserv?map=3D/home/earevalo/mapserver-4.8.3/te=
sts/test.map&layer=3DTesting&mode=3Dmap>=20
=20
Note that you used a colon instead of an equals sign.
=20
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] =
On Behalf Of Eduardo Ar=E9valo
Sent: Thursday, May 04, 2006 11:06 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] error en http
=09
=09
please help:
=09
http://10.1.6.46/cgi-bin/mapserv?map:/home/earevalo/mapserver-4.8.3/tests=
/test.map&layer=3DTesting&mode=3Dmap=20
=09
error
=09
loadMap(): Web application error. CGI variable "map" is not set.
=09
=09
=09
------_=_NextPart_001_01C66F9D.1F12D98A
Content-Type: text/html;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Message</TITLE>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2873" name=3DGENERATOR></HEAD>
<BODY>
<DIV><SPAN class=3D211410517-04052006><FONT face=3DArial color=3D#0000ff =
size=3D2>From=20
your example, I would try:</FONT></SPAN></DIV>
size=3D2></FONT></SPAN> </DIV>
size=3D2><A=20
href=3D"http://10.1.6.46/cgi-bin/mapserv?map=3D/home/earevalo/mapserver-4=
.8.3/tests/test.map&layer=3DTesting&mode=3Dmap "><FONT=20
face=3D"Times New Roman"=20
size=3D3>http://10.1.6.46/cgi-bin/mapserv?map=3D/home/earevalo/mapserver-=
4.8.3/tests/test.map&layer=3DTesting&mode=3Dmap=20
</FONT></A></FONT></SPAN></DIV>
size=3D2>Note=20
that you used a colon instead of an equals sign.</FONT></SPAN></DIV>
size=3D2>David.</DIV>
<DIV><BR></DIV></FONT></SPAN>
<BLOCKQUOTE style=3D"MARGIN-RIGHT: 0px">
<DIV></DIV>
<DIV class=3DOutlookMessageHeader lang=3Den-us dir=3Dltr =
align=3Dleft><FONT=20
face=3DTahoma size=3D2>-----Original Message-----<BR><B>From:</B> UMN =
MapServer=20
Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] <B>On Behalf Of =
</B>Eduardo=20
Ar=E9valo<BR><B>Sent:</B> Thursday, May 04, 2006 11:06 =
AM<BR><B>To:</B>=20
MAPSERVER-USERS at LISTS.UMN.EDU<BR><B>Subject:</B> [UMN_MAPSERVER-USERS] =
error=20
en http<BR><BR></FONT></DIV>please help:<BR><BR><A=20
href=3D"http://10.1.6.46/cgi-bin/mapserv?map:/home/earevalo/mapserver-4.8=
.3/tests/test.map&layer=3DTesting&mode=3Dmap">http://10.1.6.46/cg=
i-bin/mapserv?map:/home/earevalo/mapserver-4.8.3/tests/test.map&layer=
</A><BR><BR>error<BR><BR>loadMap(): Web application error. CGI =
variable "map"=20
is not set.<BR><BR><BR></BLOCKQUOTE></BODY></HTML>
------_=_NextPart_001_01C66F9D.1F12D98A--
More information about the MapServer-users
