[MapServer-users] OGR wkbMultiPolygon is working on 7.6.4 version?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Sep 3 05:27:48 PDT 2024
Hi Carlos,
I'll put some points that I might go through, if I was in your shoes:
- use ogrinfo (on your .ovf) to get the extents of the layer, and add
that to the MAP-level EXTENT parameter
- remove all other layers, and all PROJECTION blocks, for the test
- remove all validation parameters, and OPACITY
- change the layer STATUS to ON
- use the map2img command (shp2img for your version), with the switch
"-all_debug 5"
- look in that response from map2img, for a query done to your database,
and paste that query in MySQL's commandline tool (PostgreSQL has "psql",
and if I remember correctly MySQL has "mysql" ?) to see if the exact
query returns the correct response
But usually when I get an empty map it is because of a projection issue
(that's why removing all projection blocks and other layers is a good test).
Maybe one of the above gives you can idea.
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
On 2024-09-03 6:33 a.m., Carlos Neves (LREC) via MapServer-users wrote:
> Hi List,
> I have a MultiPolygon Mysql Table with wildfire data (see below) running
> on Mpaserver version 7.6.4, there is no error in the log, but the Map
> doesn't display. Any Idea? Thanks in advance
> The wildfire.ovf file:
> <OGRVRTDataSource>
> <OGRVRTLayer name="wildfire">
> <SrcDataSource>MYSQL:alarms,user=monitor,password=****,host=localhost,port=3306,tables=wildfire</SrcDataSource>
> <SrcSQL>SELECT * FROM wildfire</SrcSQL>
> <GeometryType>wkbMultiPolygon</GeometryType>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> and a MAP file like:
> LAYER # WILDFIRE LAYER
> NAME wildfire
> CONNECTIONTYPE OGR
> CONNECTION "wildfire.ovf"
> TYPE POLYGON
> STATUS DEFAULT
> DATA "wildfire"
> METADATA
> "wms_title" "wildfire"
> "qstring_validation_pattern" ".*"
> END
> VALIDATION
> "qstring" ".*"
> END
> LABELITEM "AREA_HA"
> CLASS
> NAME 'Wildfire Test'
> STYLE
> OUTLINECOLOR 0 0 0 #stroke
> WIDTH .1
> COLOR 255 0 0 #Red Wildfire Polygon
> OPACITY 50
> END
> LABEL
> FONT "tahoma"
> TYPE TRUETYPE
> SIZE 5
> BUFFER 1
> FORCE TRUE
> POSITION CC
> COLOR 255 255 255
> END #END LABEL
> END # CLASS
> END #MAP
> Best Regards
> Carlos
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
