[MapServer-users] LABEL wrap, maxlength oddity
Scott public at postholer.com
Mon Sep 16 14:19:48 PDT 2024
Removing MAXLENGTH altogether did the trick!
Yeah, updating the docs seems appropriate.
Thanks for the quick response Jeff!
On 9/16/24 13:57, Jeff McKenna via MapServer-users wrote:
> Hi Scott!
> This might be from our more strict checks in MapServer >= 8.  I tried
> the msautotest for wrap (
> https://github.com/MapServer/MapServer/blob/main/msautotest/renderers/labels-wrap.map ), and if I set "MAXLENGTH 0" I get your error (I do see in the docs a hidden line of "must be greater than zero", which is odd because above that in the docs it explains the case for "maxlength = 0").
> If I comment out the MAXLENGTH parameter completely, it wraps at the "|"
> character as expected (please also try that for your mapfile - does that
> solve it?).
> In other words, maybe I just need to update the docs, to not set
> maxlength, if you want to wrap at the wrap character.
> Thoughts?
> thanks,
> -jeff
More information about the MapServer-users mailing list
