[MapServer-users] OGR wkbMultiPolygon is working on 7.6.4 version?
Carlos Neves (LREC) cneves at lrec.pt
Tue Sep 3 02:33:12 PDT 2024
Hi List,
I have a MultiPolygon Mysql Table with wildfire data (see below) running
on Mpaserver  version 7.6.4,  there is no error in the log, but the Map
doesn't display. Any Idea? Thanks in advance
The wildfire.ovf file:
<OGRVRTDataSource>
     <OGRVRTLayer name="wildfire">
<SrcDataSource>MYSQL:alarms,user=monitor,password=****,host=localhost,port=3306,tables=wildfire</SrcDataSource>
         <SrcSQL>SELECT * FROM wildfire</SrcSQL>
         <GeometryType>wkbMultiPolygon</GeometryType>
     </OGRVRTLayer>
</OGRVRTDataSource>
and a MAP file like:
LAYER  # WILDFIRE LAYER
         NAME wildfire
         CONNECTIONTYPE OGR
          CONNECTION "wildfire.ovf"
         TYPE POLYGON
         STATUS DEFAULT
         DATA "wildfire"
         METADATA
             "wms_title" "wildfire"
             "qstring_validation_pattern" ".*"
         END
          VALIDATION
             "qstring" ".*"
         END
         LABELITEM "AREA_HA"
         CLASS
             NAME 'Wildfire Test'
             STYLE
                                 OUTLINECOLOR 0 0 0   #stroke
                                 WIDTH .1
                                 COLOR 255 0 0  #Red  Wildfire Polygon
                                 OPACITY 50
             END
             LABEL
                     FONT "tahoma"
                     TYPE TRUETYPE
                      SIZE 5
                      BUFFER 1
                      FORCE TRUE
                      POSITION CC
                     COLOR 255 255 255
             END #END LABEL
     END # CLASS
END #MAP
Best Regards
Carlos
More information about the MapServer-users mailing list
