[MapServer-users] OGCAPI
Jörg Thomsen (WhereGroup) joerg.thomsen at wheregroup.com
Wed Apr 9 00:28:37 PDT 2025
Hello Sven,
somehow qgis tried to use a wfs-request. I had to configure your service
explizit as OGC-Api (not "Maximum") and delete the cache in QGIS. Now I
can use both collections.
The kdb_alle works not for all items, I have tried up to 10.000 (in QGIS
with checkbox 'only load items i curent mapxtent'.
https://kulturdb.de/cgi-bin/mapserv/kdb_ogcapi/ogcapi/collections/kdb_alle/items?f=json&limit=10000
Don't know what ist happening, perhaps the MapServer log can tell you more.
Jörg
Am 08.04.25 um 17:56 schrieb Schroeter via MapServer-users:
> Hi all,
> I am currently testing the ogcapi function in the current Mapserver 8.4
> and already have an example online:
> https://kulturdb.de/cgi-bin/mapserv/kdb_ogcapi/ogcapi/collections?f=html
> In the first collection, all objects (approx. 48,000 point objects from
> a Postgis DB) are queried. Unfortunately extremely slow.
> If I query all objects via a WMS, they come very quickly, it should not
> be due to the DB or the connection, everything is cleanly indexed etc.:
> https://kulturdb.de/cgi-bin/mapserv?map=kdb&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=49.49%2C6.0739%2C50.4%2C7.296&CRS=EPSG%3A4326&WIDTH=762&HEIGHT=588&LAYERS=kdb_alle&STYLES=&FORMAT=image%2Fpng
> With the second collection with only 333 objects, it works quite well:
> https://kulturdb.de/cgi-bin/mapserv/kdb_ogcapi/ogcapi/collections/kdb_brunnen/items?f=html
> Here is the map file for it
> MAP
>    NAME "kdb_trier"
>    STATUS ON
>    SIZE 400 400
>    EXTENT 6.074 49.492 7.296 50.435
>    UNITS METERS
>    PROJECTION
>      "init=epsg:4326"
>    END
>    WEB
>    METADATA
>      # OGC API Features Konfiguration
>      "ows_enable_request"                     "*"
>      "ows_getfeatureinfo_formatlist"
> "text/plain,text/html,application/json,application/vnd.ogc.gml,gml"
>      "oga_onlineresource"
> "https://kulturdb.de/cgi-bin/mapserv/kdb_ogcapi/ogcapi"
>      "oga_title"                              "KDB Trier"
>      "oga_abstract"                           "Objekte der
> Kulturdatenbank der Region Trier"
>      "oga_srs"                                "EPSG:25832 EPSG:4326
> EPSG:3857"
>      "oga_html_template_directory"
> "/var/www/html/ogcapi/templates/html-bootstrap4/"
>      "oga_extent"                             "6.074 49.492 7.296 50.435"
>      "oga_use_default_extent_for_getfeature"  "true"
>      "oga_limit_default"                      "10"
>      "oga_limit_max"                          "500"
>      "oga_paging"                             "true"
>      "oga_paging_linkheader"                  "true"
>      "gml_include_items"                         "all"
>      "gml_featureid"                             "lfdnr"
>    END
>      TEMPLATE "/var/www/mapserver/template/dummy.html"
>    END
>   OUTPUTFORMAT
>      NAME "png"
>      DRIVER AGG/PNG
>      MIMETYPE "image/png"
>      IMAGEMODE RGB
>      EXTENSION "png"
>      FORMATOPTION "GAMMA=0.75"
>    END
>    OUTPUTFORMAT
>      NAME "application/json"
>      DRIVER "OGR/GEOJSON"
>      MIMETYPE "application/json"
>      FORMATOPTION "FORM=SIMPLE"
>      FORMATOPTION "STORAGE=memory"
>    END
>    SYMBOL
>      NAME "circle"
>      TYPE ELLIPSE
>      POINTS
>        1 1
>      END
>      FILLED TRUE
>    END
>    LAYER
>      NAME "kdb_alle"
>      TYPE POINT
>      STATUS ON
>      INCLUDE "_connection_kdb.inc"
>      DATA "the_geom FROM kdb_kultur_ogr  USING UNIQUE lfdnr"
>      PROJECTION
>        "init=epsg:4326"
>      END
>      METADATA
>        # OGC API Features Metadaten
>        "oga_title"                              "KDB Trier - alle Objekte"
>        "oga_description"                        "Alle Objekte der
>        "oga_id_field"                           "lfdnr"
>        "oga_queryable"                          "true"
>        "ows_title"                                "KDB Trier - alle Objekte"
>        "ows_abstract"                            "Alle Objekte der
>        "oga_paging"                             "true"
>      END
>      CLASS
>        NAME "KDB"
>        STYLE
>          SYMBOL "circle"
>          SIZE 6
>          COLOR 255 0 0
>          OUTLINECOLOR 255 255 255
>        END
>      END
>    END  # LAYER
>    LAYER
>      NAME "kdb_brunnen"
>      TYPE POINT
>      STATUS ON
>      DATA "the_geom FROM (SELECT * FROM kdb_kultur_ogr WHERE b_kateg =
> 'Brunnen') AS foo  USING UNIQUE lfdnr"
>      PROJECTION
>        "init=epsg:4326"
>      END
>      METADATA
>        "oga_title"                               "KDB Trier - Brunnen"
>        "oga_description"                         "Brunnen Objekte der
> 50.435"
>        "ows_title"                                 "KDB Trier - Brunnen"
>        "ows_abstract"                             "Brunnen Objekte der
>        "oga_paging"                             "true"
>      END
>      CLASS
>        NAME "KDB"
>        STYLE
>          SYMBOL "circle"
>          SIZE 6
>          COLOR 255 0 0
>        END
>      END
>    END  # LAYER
> END  # MAP
> THE MS Version:
> MapServer version 8.4.0 PROJ version 9.1 GDAL version 3.6 OUTPUT=PNG
> OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=OGCAPI_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE INPUT=FLATGEOBUF
> 1. How can I speed up the display for the first collection?
> 2. the collections are not recognised in QGIS, What ist wrong?
> Thanx
> Sven
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
WhereGroup Shorts 2025 - am 15. Mai
Im Fokus: PostgreSQL & PostGIS
Online als Zoom-Meeting
https://wheregroup-shorts.de
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the MapServer-users mailing list
