[MapServer-users] OGCAPI
    Schroeter
    schroeter at netgis.de
    Wed Apr  9 01:50:55 PDT 2025
Hello Jörg,
thanks for the answer, strangely enough Qgis (version 3.4) is still
stubbornly trying to send me a WFS request. I have now also cleared the
cache and explicitly set OGC-Api. The wrong request is always set in the
diagnostic tools. Which url do you enter as the source in Qgis? Have you
ever created a service with > 40,000 objects?
Sven
Am 09.04.2025 um 09:28 schrieb Jörg Thomsen (WhereGroup) via
MapServer-users:
> Hello Sven,
> somehow qgis tried to use a wfs-request. I had to configure your
> service explizit as OGC-Api (not "Maximum") and delete the cache in
> QGIS. Now I can use both collections.
> The kdb_alle works not for all items, I have tried up to 10.000 (in
> QGIS with checkbox 'only load items i curent mapxtent'.
> https://kulturdb.de/cgi-bin/mapserv/kdb_ogcapi/ogcapi/collections/kdb_alle/items?f=json&limit=10000
> Don't know what ist happening, perhaps the MapServer log can tell you
> more.
> Jörg
> Am 08.04.25 um 17:56 schrieb Schroeter via MapServer-users:
>> Hi all,
>> I am currently testing the ogcapi function in the current Mapserver
>> 8.4 and already have an example online:
>> https://kulturdb.de/cgi-bin/mapserv/kdb_ogcapi/ogcapi/collections?f=html
>> In the first collection, all objects (approx. 48,000 point objects
>> from a Postgis DB) are queried. Unfortunately extremely slow.
>> If I query all objects via a WMS, they come very quickly, it should
>> not be due to the DB or the connection, everything is cleanly indexed
>> etc.:
>> https://kulturdb.de/cgi-bin/mapserv?map=kdb&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=49.49%2C6.0739%2C50.4%2C7.296&CRS=EPSG%3A4326&WIDTH=762&HEIGHT=588&LAYERS=kdb_alle&STYLES=&FORMAT=image%2Fpng
>> With the second collection with only 333 objects, it works quite well:
>> https://kulturdb.de/cgi-bin/mapserv/kdb_ogcapi/ogcapi/collections/kdb_brunnen/items?f=html
>> Here is the map file for it
>> MAP
>>    NAME "kdb_trier"
>>    STATUS ON
>>    SIZE 400 400
>>    EXTENT 6.074 49.492 7.296 50.435
>>    UNITS METERS
>>    PROJECTION
>>      "init=epsg:4326"
>>    END
>>    WEB
>>    METADATA
>>      # OGC API Features Konfiguration
>>      "ows_enable_request"                     "*"
>>      "ows_getfeatureinfo_formatlist"
>> "text/plain,text/html,application/json,application/vnd.ogc.gml,gml"
>>      "oga_onlineresource"
>> "https://kulturdb.de/cgi-bin/mapserv/kdb_ogcapi/ogcapi"
>>      "oga_title"                              "KDB Trier"
>>      "oga_abstract"                           "Objekte der
>> Kulturdatenbank der Region Trier"
>>      "oga_srs"                                "EPSG:25832 EPSG:4326
>> EPSG:3857"
>>      "oga_html_template_directory"
>> "/var/www/html/ogcapi/templates/html-bootstrap4/"
>>      "oga_extent"                             "6.074 49.492 7.296
>> 50.435"
>>      "oga_use_default_extent_for_getfeature"  "true"
>>      "oga_limit_default"                      "10"
>>      "oga_limit_max"                          "500"
>>      "oga_paging"                             "true"
>>      "oga_paging_linkheader"                  "true"
>>      "gml_include_items"                         "all"
>>      "gml_featureid"                             "lfdnr"
>>    END
>>      TEMPLATE "/var/www/mapserver/template/dummy.html"
>>    END
>>   OUTPUTFORMAT
>>      NAME "png"
>>      DRIVER AGG/PNG
>>      MIMETYPE "image/png"
>>      IMAGEMODE RGB
>>      EXTENSION "png"
>>      FORMATOPTION "GAMMA=0.75"
>>    END
>>    OUTPUTFORMAT
>>      NAME "application/json"
>>      DRIVER "OGR/GEOJSON"
>>      MIMETYPE "application/json"
>>      FORMATOPTION "FORM=SIMPLE"
>>      FORMATOPTION "STORAGE=memory"
>>    END
>>    SYMBOL
>>      NAME "circle"
>>      TYPE ELLIPSE
>>      POINTS
>>        1 1
>>      END
>>      FILLED TRUE
>>    END
>>    LAYER
>>      NAME "kdb_alle"
>>      TYPE POINT
>>      STATUS ON
>>      INCLUDE "_connection_kdb.inc"
>>      DATA "the_geom FROM kdb_kultur_ogr  USING UNIQUE lfdnr"
>>      PROJECTION
>>        "init=epsg:4326"
>>      END
>>      METADATA
>>        # OGC API Features Metadaten
>>        "oga_title"                              "KDB Trier - alle
>> Objekte"
>>        "oga_description"                        "Alle Objekte der
>>        "oga_id_field"                           "lfdnr"
>>        "oga_queryable"                          "true"
>> 50.435"
>>        "ows_title"                                "KDB Trier - alle
>> Objekte"
>>        "ows_abstract"                            "Alle Objekte der
>> 50.435"
>>        "oga_paging"                             "true"
>>      END
>>      CLASS
>>        NAME "KDB"
>>        STYLE
>>          SYMBOL "circle"
>>          SIZE 6
>>          COLOR 255 0 0
>>          OUTLINECOLOR 255 255 255
>>        END
>>      END
>>    END  # LAYER
>>    LAYER
>>      NAME "kdb_brunnen"
>>      TYPE POINT
>>      STATUS ON
>>      DATA "the_geom FROM (SELECT * FROM kdb_kultur_ogr WHERE b_kateg
>> = 'Brunnen') AS foo  USING UNIQUE lfdnr"
>>      PROJECTION
>>        "init=epsg:4326"
>>      END
>>      METADATA
>>        "oga_title"                               "KDB Trier - Brunnen"
>>        "oga_description"                         "Brunnen Objekte der
>> 50.435"
>>        "ows_title"                                 "KDB Trier - Brunnen"
>>        "ows_abstract"                             "Brunnen Objekte
>> der Kulturdatenbank der Region Trier"
>> 50.435"
>>        "oga_paging"                             "true"
>>      END
>>      CLASS
>>        NAME "KDB"
>>        STYLE
>>          SYMBOL "circle"
>>          SIZE 6
>>          COLOR 255 0 0
>>        END
>>      END
>>    END  # LAYER
>> END  # MAP
>> THE MS Version:
>> MapServer version 8.4.0 PROJ version 9.1 GDAL version 3.6 OUTPUT=PNG
>> OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>> SUPPORTS=SOS_SERVER SUPPORTS=OGCAPI_SERVER SUPPORTS=FASTCGI
>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR
>> INPUT=GDAL INPUT=SHAPEFILE INPUT=FLATGEOBUF
>> 1. How can I speed up the display for the first collection?
>> 2. the collections are not recognised in QGIS, What ist wrong?
>> Thanx
>> Sven
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
