[MapServer-users] OGCAPI
Seth G sethg at geographika.co.uk
Wed Apr 9 06:32:58 PDT 2025
Hi Sven,
I ran into a couple of performance issues with PostGIS / OGC Features API, see:
https://github.com/MapServer/MapServer/pull/7198
https://github.com/MapServer/MapServer/pull/7197
So maybe try setting the type for your ID field, and wfs_use_default_extent_for_getfeature. If you are using MapServer 8.4 they might help.
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Wed, Apr 9, 2025, at 11:52 AM, Schroeter via MapServer-users wrote:
> Hi Jukka,
> Thank you very much, that was the solution for QGIS.
> I now also have an interim solution for performance.
> I have exported the table as a geopackage and connected it, and lo and behold, everything runs very quickly:
> https://kulturdb.de/cgi-bin/mapserv/kdb_ogcapi/ogcapi/collections/kdb_alle/items?f=json&limit=10000
> Since my queries to the Postgis table also run very quickly via PHP, it can't really be the Postgis DB. Is the performance problem in MS with Postgis a bug?
> Greetings
> Sven Schröter
> NETGIS GbR
> Benediktinerstr. 32a
> 54292 Trier
> Tel.: 0651-1704731
> Fax: 0651-1704733
> schroeter at netgis.de
> www.netgis.de
> Am 09.04.2025 um 11:03 schrieb Rahkonen Jukka:
>> The URL to use for the connection is the URL of the landing page
>> That link opens as http on a browser but QGIS knows how to read the document as JSON.
>> -Jukka Rahkonen-
>> ________________________________________
>> Lähettäjä: MapServer-users käyttäjän Schroeter via MapServer-users puolesta
>> Lähetetty: Keskiviikko 9. huhtikuuta 2025 11.50
>> Vastaanottaja: mapserver-users at lists.osgeo.org
>> Aihe: Re: [MapServer-users] OGCAPI
>> Hello Jörg,
>> thanks for the answer, strangely enough Qgis (version 3.4) is still
>> stubbornly trying to send me a WFS request. I have now also cleared the
>> cache and explicitly set OGC-Api. The wrong request is always set in the
>> diagnostic tools. Which url do you enter as the source in Qgis? Have you
>> ever created a service with > 40,000 objects?
>> Sven
>> Am 09.04.2025 um 09:28 schrieb Jörg Thomsen (WhereGroup) via
>> MapServer-users:
>>> Hello Sven,
>>> somehow qgis tried to use a wfs-request. I had to configure your
>>> service explizit as OGC-Api (not "Maximum") and delete the cache in
>>> QGIS. Now I can use both collections.
>>> The kdb_alle works not for all items, I have tried up to 10.000 (in
>>> QGIS with checkbox 'only load items i curent mapxtent'.
>>> Don't know what ist happening, perhaps the MapServer log can tell you
>>> more.
>>> Jörg
>>> Am 08.04.25 um 17:56 schrieb Schroeter via MapServer-users:
>>>> Hi all,
>>>> I am currently testing the ogcapi function in the current Mapserver
>>>> 8.4 and already have an example online:
>>>> https://kulturdb.de/cgi-bin/mapserv/kdb_ogcapi/ogcapi/collections?f=html
>>>> In the first collection, all objects (approx. 48,000 point objects
>>>> from a Postgis DB) are queried. Unfortunately extremely slow.
>>>> If I query all objects via a WMS, they come very quickly, it should
>>>> not be due to the DB or the connection, everything is cleanly indexed
>>>> etc.:
>>>> https://kulturdb.de/cgi-bin/mapserv?map=kdb&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=49.49%2C6.0739%2C50.4%2C7.296&CRS=EPSG%3A4326&WIDTH=762&HEIGHT=588&LAYERS=kdb_alle&STYLES=&FORMAT=image%2Fpng
>>>> With the second collection with only 333 objects, it works quite well:
>>>> https://kulturdb.de/cgi-bin/mapserv/kdb_ogcapi/ogcapi/collections/kdb_brunnen/items?f=html
>>>> Here is the map file for it
>>>> MAP
>>>>    NAME "kdb_trier"
>>>>    STATUS ON
>>>>    SIZE 400 400
>>>>    EXTENT 6.074 49.492 7.296 50.435
>>>>    UNITS METERS
>>>>    PROJECTION
>>>>      "init=epsg:4326"
>>>>    END
>>>>    WEB
>>>>    METADATA
>>>>      # OGC API Features Konfiguration
>>>>      "ows_enable_request"                     "*"
>>>>      "ows_getfeatureinfo_formatlist"
>>>> "text/plain,text/html,application/json,application/vnd.ogc.gml,gml"
>>>>      "oga_onlineresource"
>>>> "https://kulturdb.de/cgi-bin/mapserv/kdb_ogcapi/ogcapi"
>>>>      "oga_title"                              "KDB Trier"
>>>>      "oga_abstract"                           "Objekte der
>>>> Kulturdatenbank der Region Trier"
>>>>      "oga_srs"                                "EPSG:25832 EPSG:4326
>>>> EPSG:3857"
>>>>      "oga_html_template_directory"
>>>> "/var/www/html/ogcapi/templates/html-bootstrap4/"
>>>>      "oga_extent"                             "6.074 49.492 7.296
>>>> 50.435"
>>>>      "oga_use_default_extent_for_getfeature"  "true"
>>>>      "oga_limit_default"                      "10"
>>>>      "oga_limit_max"                          "500"
>>>>      "oga_paging"                             "true"
>>>>      "oga_paging_linkheader"                  "true"
>>>>      "gml_include_items"                         "all"
>>>>      "gml_featureid"                             "lfdnr"
>>>>    END
>>>>      TEMPLATE "/var/www/mapserver/template/dummy.html"
>>>>    END
>>>>   OUTPUTFORMAT
>>>>      NAME "png"
>>>>      DRIVER AGG/PNG
>>>>      MIMETYPE "image/png"
>>>>      IMAGEMODE RGB
>>>>      EXTENSION "png"
>>>>      FORMATOPTION "GAMMA=0.75"
>>>>    END
>>>>    OUTPUTFORMAT
>>>>      NAME "application/json"
>>>>      DRIVER "OGR/GEOJSON"
>>>>      MIMETYPE "application/json"
>>>>      FORMATOPTION "FORM=SIMPLE"
>>>>      FORMATOPTION "STORAGE=memory"
>>>>    END
>>>>    SYMBOL
>>>>      NAME "circle"
>>>>      TYPE ELLIPSE
>>>>      POINTS
>>>>        1 1
>>>>      END
>>>>      FILLED TRUE
>>>>    END
>>>>    LAYER
>>>>      NAME "kdb_alle"
>>>>      TYPE POINT
>>>>      STATUS ON
>>>>      INCLUDE "_connection_kdb.inc"
>>>>      DATA "the_geom FROM kdb_kultur_ogr  USING UNIQUE lfdnr"
>>>>      PROJECTION
>>>>        "init=epsg:4326"
>>>>      END
>>>>      METADATA
>>>>        # OGC API Features Metadaten
>>>>        "oga_title"                              "KDB Trier - alle
>>>> Objekte"
>>>>        "oga_description"                        "Alle Objekte der
>>>>        "oga_id_field"                           "lfdnr"
>>>>        "oga_queryable"                          "true"
>>>> 50.435"
>>>>        "ows_title"                                "KDB Trier - alle
>>>> Objekte"
>>>>        "ows_abstract"                            "Alle Objekte der
>>>> 50.435"
>>>>        "oga_paging"                             "true"
>>>>      END
>>>>      CLASS
>>>>        NAME "KDB"
>>>>        STYLE
>>>>          SYMBOL "circle"
>>>>          SIZE 6
>>>>          COLOR 255 0 0
>>>>          OUTLINECOLOR 255 255 255
>>>>        END
>>>>      END
>>>>    END  # LAYER
>>>>    LAYER
>>>>      NAME "kdb_brunnen"
>>>>      TYPE POINT
>>>>      STATUS ON
>>>>      DATA "the_geom FROM (SELECT * FROM kdb_kultur_ogr WHERE b_kateg
>>>> = 'Brunnen') AS foo  USING UNIQUE lfdnr"
>>>>      PROJECTION
>>>>        "init=epsg:4326"
>>>>      END
>>>>      METADATA
>>>>        "oga_title"                               "KDB Trier - Brunnen"
>>>>        "oga_description"                         "Brunnen Objekte der
>>>> 50.435"
>>>>        "ows_title"                                 "KDB Trier - Brunnen"
>>>>        "ows_abstract"                             "Brunnen Objekte
>>>> der Kulturdatenbank der Region Trier"
>>>> 50.435"
>>>>        "oga_paging"                             "true"
>>>>      END
>>>>      CLASS
>>>>        NAME "KDB"
>>>>        STYLE
>>>>          SYMBOL "circle"
>>>>          SIZE 6
>>>>          COLOR 255 0 0
>>>>        END
>>>>      END
>>>>    END  # LAYER
>>>> END  # MAP
>>>> THE MS Version:
>>>> MapServer version 8.4.0 PROJ version 9.1 GDAL version 3.6 OUTPUT=PNG
>>>> OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>>>> SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>>>> SUPPORTS=SOS_SERVER SUPPORTS=OGCAPI_SERVER SUPPORTS=FASTCGI
>>>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR
>>>> INPUT=GDAL INPUT=SHAPEFILE INPUT=FLATGEOBUF
>>>> 1. How can I speed up the display for the first collection?
>>>> 2. the collections are not recognised in QGIS, What ist wrong?
>>>> Thanx
>>>> Sven
>>>> _______________________________________________
>>>> MapServer-users mailing list
>>>> MapServer-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250409/9f7fb6d6/attachment-0001.htm>
More information about the MapServer-users mailing list
