[MapServer-users] GetFeatureInfo from VRT COG stack
Scott public at postholer.com
Tue Apr 22 10:50:47 PDT 2025
If you do a gdallocationinfo on your .vrt using lon/lat, does it give
all values or just one?
If you only get one value, you may need specify that they are individual
COGs. Using gdalbuildvrt that may look like:
gdalbuildvrt -separate mycogs.vrt /path/to/cogs/*.tif
I'm not sure how that will translate to getFeatureInfo, but it ensures
your .vrt is correctly made.
On 4/22/25 08:03, Eloi Ribeiro via MapServer-users wrote:
> Dear all,
> I have a stack of COG files that fully overlap, with the same extent,
> EPSG and size.
> I have created a VRT <https://cloud.eloiribeiro.eu/s/WtKgesFJCHnYSCQ>,
> mapfile <https://cloud.eloiribeiro.eu/s/sCoqeWaLq6eSKqA> and
> getfeatureinfo template <https://cloud.eloiribeiro.eu/s/35Z2e8nkifnoC6w>.
> The goal is to get the pixel value from all layers (COG files) in the
> VRT in one go with a GetFeatureInfo request. Is this even possible? For
> now I only get the value of the first layer. The response looks like this: /
> Layer: PH-GSOC Coords: 120.85598, 15.638156 Value: 37.550686/.
> What I need to do in order to get the values from all layers, instead of
> only the first one?
> Kind regards,
> Eloi
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
