[MapServer-users] Subject: GetFeatureInfo works only for first record in FlatGeobuf TILEINDEX (MapServer 8.6.0-beta2)
Marcin Niemyjski mniemyjski at cloudferro.com
Fri Dec 12 03:23:35 PST 2025
Hi all,
MY MAPFILE: https://pastebin.com/6A98L6V7
I am running into an issue with WMS GetFeatureInfo when using FlatGeobuf (FGB) as a TILEINDEX source in MapServer. The problem appears to be related to how MapServer / OGR handles multiple records inside a FlatGeobuf tile index.
Environment:
- MapServer: 8.6.0-beta2
- GDAL: 3.12.0
- PROJ: 9.7.0
- OS: Debian Bookworm (Docker)
TileIndex structure:
I am using FlatGeobuf as a tile index, with a schema similar to a classic shapefile tile index.
The TILEITEM column is called "location" and contains both the file path and the layer name,
separated by a comma:
location
data/CLMS_UA_LCU_S2021_V025ha_BA001L1_SARAJEVO_03035_V01_R01_20250523.fgb,CLMS_UA_LCU_S2021_V025ha_BA001L1_SARAJEVO_03035_V01_R01_20250523
data/CLMS_UA_LCU_S2021_V025ha_AT001L3_WIEN_03035_V01_R01_20250418.fgb,CLMS_UA_LCU_S2021_V025ha_AT001L3_WIEN_03035_V01_R01_20250418
Each referenced FlatGeobuf file contains exactly one vector layer, and the layer name matches
the name provided after the comma in the tile index.
Problem description:
- I have vector layers configured in MapServer using CONNECTIONTYPE OGR with TILEINDEX pointing to an FGB file.
- The layers are only visible at large scales (MAXSCALEDENOM 300000), where vector data is queried.
- When issuing a WMS GetFeatureInfo request at an appropriate zoom level:
  - GetFeatureInfo works correctly for features coming from the FIRST record in the tile index.
  - Features coming from any subsequent tile index record never return GetFeatureInfo results.
- The request itself is valid (correct bbox, x/y, tolerance, scale), and rendering works correctly
  for all tiles — only GetFeatureInfo is affected.
Additional observations:
- Reordering records inside the FlatGeobuf tile index changes which dataset GetFeatureInfo works for.
  Whichever record is first starts working; the others stop working.
- If I bypass the tile index and connect directly to a single FlatGeobuf file using:
  CONNECTION "path/to/file.fgb"
  DATA "layer_name"
  then GetFeatureInfo works as expected.
- To further isolate the issue, I created a separate MapServer layer only for the Vienna dataset
  (the dataset affected by the problem), with an explicit CONNECTION and DATA pointing directly
  to the FlatGeobuf file and its internal layer name (no TILEINDEX involved).
- In this setup, with the layer name explicitly defined, GetFeatureInfo works correctly and
  consistently for Vienna features.
- This strongly suggests that the problem is not related to the data itself, styles, templates,
  or scale settings, but specifically to the use of FlatGeobuf as a TILEINDEX source during
  GetFeatureInfo processing.
- It appears that during GetFeatureInfo MapServer / OGR only evaluates the first tile index
  record and does not properly iterate over or reset OGR datasets for subsequent records,
  especially when different internal layer names are involved.
My suspicion is that this may be a limitation or bug in how FlatGeobuf is handled as a TILEINDEX
source, particularly for GetFeatureInfo requests.
Has anyone encountered similar behaviour when using FlatGeobuf tile indexes with GetFeatureInfo,
or can confirm whether this is a known limitation in MapServer or GDAL/OGR?
Thanks,
Marcin
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20251212/541b2ecd/attachment-0001.htm>
More information about the MapServer-users mailing list
