[MapServer-users] Wrong and inconsistent GetFeatureInfo result for CLUSTER layer
    Guldberg, Erik
    Erik.Guldberg at ra.no
    Fri Feb 14 05:50:58 PST 2025
I have a WMS service, https://kart.ra.no/wms/brukerminner, where I have problems getting correct getFeatureInfo results from a layer with CLUSTER content.
It contains the cluster layer and a regular point layer for the same data. The regular point layer is shown at 1:50 000.
For single objects in both the cluster layer, I want to be able to use getFeatureInfo. This works, but the problem is that the results most of the time are wrong, and that they change for time to time, likely due to change in zoom level. For the regular point layer, the result is always correct. I've also created a test cluster layer without the scale limit, and that also gives the correct result if I zoom in enough.
All the symbols are placed correctly in the map, for all layers. I've used the database, and also this OGC API service (that uses the same data source as the WMS) as a reference: https://api.ra.no/brukerminner
I'm using MapServer version 7.6.4.
Some example queries, using QGIS.
Wrong result. The object I get in the getfeatureinfo is 64 km away from where I clicked.
https://kart.ra.no/wms/brukerminner?language=nor&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetFeatureInfo&BBOX=760392.02671199827454984%2C8263040.88853696268051863%2C1033357.36004533339291811%2C8407916.1385369636118412&CRS=EPSG%3A3857&WIDTH=1984&HEIGHT=1053&LAYERS=Brukerminner&STYLES=&FORMAT=image%2Fpng&QUERY_LAYERS=Brukerminner&INFO_FORMAT=text%2Fhtml&I=1069&J=616&FEATURE_COUNT=10
Zoomed in a bit more gives another, wrong result. This is 8.7 km away from where I clicked:
https://kart.ra.no/wms/brukerminner?language=nor&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetFeatureInfo&BBOX=871972.11004533257801086%2C8307721.07603696547448635%2C940213.44337866583373398%2C8343939.88853696547448635&CRS=EPSG%3A3857&WIDTH=1984&HEIGHT=1053&LAYERS=Brukerminner&STYLES=&FORMAT=image%2Fpng&QUERY_LAYERS=Brukerminner&INFO_FORMAT=text%2Fhtml&I=1022&J=627&FEATURE_COUNT=10
This is the Test-layer, how it looks now. I've tried different variations of PROCESSING settings.
LAYER
                NAME "TEST"
                DEBUG 5
                TYPE POINT
                STATUS ON
                TEMPLATE "../templates/brukerminner.html"
                HEADER "../templates/header.html"
                FOOTER "../templates/footer.html"
    TOLERANCEUNITS pixels
                TOLERANCE 25
    # MINSCALEDENOM 50000
                METADATA
                               "wms_enable_request" "*"
        "wms_include_items" "tittel"
        "wms_title" "TEST"
                               "wms_feature_info_mime_type" "text/html"
END
PROJECTION
                "init=epsg:4326"
END
EXTENT -19.76 54.57 45.57 82.67  #4326
PROCESSING "CLOSE_CONNECTION=DEFER"
CONNECTIONTYPE POSTGIS
CONNECTION "host=host  dbname=db user=user password=password port=5432"
DATA "geom from xx.xx using unique id using srid=4326"
LABELITEM "Cluster_FeatureCount"
# PROCESSING "CLUSTER_ALGORITHM=SIMPLE"
PROCESSING "CLUSTER_GET_ALL_SHAPES=ON"
PROCESSING "ITEMS=tittel,beskrivelse,fylke,kommune,opprettet,endret,opprettet_av,linkkulturminnesok,gpsposisjon"
# PROCESSING "CLUSTER_KEEP_LOCATIONS=ON"
CLUSTER
MAXDISTANCE 50
REGION "ellipse"
END
CLASS
                NAME "Brukerminne"
    EXPRESSION ("[Cluster_FeatureCount]" = "1")
                STYLE
                               SYMBOL "brukerminne"
        COLOR 200 0 0
                               SIZE 27
        OFFSET 0 -13.5
                END
END
END
Anyone with ideas on what's wrong?
Thanks,
Erik
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250214/d6c48814/attachment-0001.htm>
More information about the MapServer-users
