[MapServer-users] Is it possible to pass an attribute to PROCESSING directive?
Seth G
sethg at geographika.co.uk
Fri Feb 21 11:45:48 PST 2025
Hi Trygve,
It might not be what you need but LAYER PROCESSING allows for run-time substitution: https://mapserver.org/cgi/runsub.html#parameters-supported
So you could control it from a URL/client-application, but obviously this wouldn't be getting values from the database.
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Thu, Feb 20, 2025, at 5:57 PM, Trygve Aspenes via MapServer-users wrote:
> Hi
> I have a netcdf file with time dimension. This time dimension is
> expressed as bands in the to mapserver from gdal. So to get the first
> time step you would set
> PROCESSING "BANDS=1" for the first timestep
> PROCESSING "BANDS=2" for the second timestep etc.
> However my client is passing the time variable as a ISO8601 in the
> request so I can not use run-time substitution as I can not find a way
> to translate a ISO8601 time to the BANDS processing(I have not looked
> into doing some rewrite)
> I was thinking of using a postgis where I could preset a time stamp to
> the correct BANDS.
> I would the set in the mapfile:
> PROCESSING "[bands]"
> where bands attribute comes from the select to a postgis, like
> select bands from table where time="some iso8601" etc
> But this does not work, and the documentation does not say it would work
> https://mapserver.org/mapfile/layer.html PROCESSING
> Any ideas how I could make this work?
> Trygve
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
