[MapServer-users] "msLoadMap(): Unable to access file..." for Mapserver 8.4.0
    Jörg Thomsen (WhereGroup)
    joerg.thomsen at wheregroup.com
    Fri Feb 28 00:07:55 PST 2025
Hi Eric,
you can trust the message 'unable to access....' Have you set the
permissions for the whole path starting with 'home' and triple checked
the path- and filename spellings?
The users home might be a non optimal place, try another directory like
/mapfiles.
Not your problem, but I won't use rewrite rules with mapserver 8, you
easily can stet mapfile aliases in the mapserver.conf without any
dependencies on the apache version or restarting the webserver.
Jörg
Am 27.02.25 um 13:11 schrieb Guldberg, Erik via MapServer-users:
> I'm trying to set up a testing environment for Mapserver 8.4.0 in
> WSL/Ubuntu, but I keep getting the error: msLoadMap(): Unable to access
> file. (/home/erik/maps/kulturminner/kulturminner.map)
> As far as I know, my setup is mostly the same as for my "real" server
> where I run 7.6.4.
> I have a mapserver.conf-file with a MS_MAP_PATTERN, and that works fine.
> *Files and folders permissions:*
> Folders: drwxr-xr-x (chmod 755)
> Files:  -rw-r--r-- (chmod 644)
> The owner is www-data, but I've also tried a regular user, which is what
> I use for the server where I run 7.6.4.
> *My Apache-setup looks like this:*
> <VirtualHost *:80>
>      SetEnv MAPSERVER_CONFIG_FILE /usr/local/etc/mapserver.conf
>      ServerAdmin webmaster at localhost
>      ErrorLog ${APACHE_LOG_DIR}/error.log
>      CustomLog ${APACHE_LOG_DIR}/access.log combined
>      ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
>      RewriteEngine On
>      RewriteRule ^/wms/(.*)
> /cgi-bin/mapserv.fcgi?map=/home/erik/maps/$1/$1.map [PT,QSA]
>      <Directory "/usr/lib/cgi-bin/">
>          AllowOverride None
>          Options +ExecCGI -MultiViews +FollowSymLinks
>          AddHandler fcgid-script .fcgi
>          Require all granted
>      </Directory>
>      Header set Access-Control-Allow-Origin "*"
> </VirtualHost>
> *URLs*
> Both URLs gives the same error
> http://localhost/cgi-bin/mapserv?map=/home/erik/maps/kulturminner/kulturminner.map <http://localhost/cgi-bin/mapserv?map=/home/erik/maps/kulturminner/kulturminner.map>
> http://localhost/wms/kulturminner <http://localhost/wms/kulturminner>
> Appreciate any help
> Erik
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
WhereGroup Shorts 2025 - am 15. Mai
Im Fokus: PostgreSQL & PostGIS
Online als ZOOM-Meeting
https://wheregroup.com/shorts/
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Tel: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the MapServer-users
