[MapServer-users] Pass Apache variable for MaServer Layer
Eduardo Kanegae
eduardo.kanegae at gmail.com
Mon Jun 2 08:06:54 PDT 2025
hi,
I'm running MapServer 8 under Debian 12/Apache 2.4 and PostgreSQL
17.5/PostGIS 3.5
and W*S already authenticated using auth/dbd under Apache/SSL, which works
fine with:
Alias /my_wms_link /path/to/mapserv.fcgi
<Location /my_wms_link>
SetHandler cgi-script
AddHandler fcgid-script .fcgi
Options ExecCGI Indexes FollowSymLinks
SetEnv MAPSERVER_CONFIG_FILE /etc/mapserver8.conf
SetEnv MS_MAPFILE /var/mapserver/etc/my_mapfile.map
Require all denied
AuthBasicProvider dbd
AuthName "Login needed!"
AuthType Basic
Require valid-user
AuthDBDUserPWQuery "SELECT u.passwd, u.login_name FROM table_users u
WHERE u.login = %s"
</Location>
But, I'm wondering if it is possible to define an apache variable here, in
.conf apache, and then to read/access this variable at layer level in
MapFile. eg.: to pass the userLoginName for
Layer->Processing(NATIVE_FILTER) and then load only specific set of data
for the given user.
I tried " SetEnv ms_user %{AUTH_USER} " or %{AUTH_USER};
By now, the only way I got it was using alternative 2 CGI script from
https://mapserver.org/cgi/wrapper.html with
QUERY_STRING="ms_user=${REMOTE_USER}&${QUERY_STRING}"
exec ${MAPSERV}
Or Apache mod_rewrite would be better in this case?
Eduardo Kanegae
https://180hs.com.br/en
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250602/70453839/attachment.htm>
More information about the MapServer-users
