[MapServer-users] INCLUDE a relative path file does not work in LABEL definition
Seth G sethg at geographika.co.uk
Wed Jun 4 00:57:56 PDT 2025
As Jukka said the path can be relative to the Mapfile. Note if you have nested includes (an INCLUDE within another INCLUDE) the paths should be relative to the top-level Mapfile, not its parent.
The error "Please correct the issue in the text tab" isn't coming from MapServer - so maybe this is related to MapManager?
You also have listed both Windows and Linux - could it be related to case-sensitive file names, or Window line-endings?
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Wed, Jun 4, 2025, at 8:46 AM, Philippe Ghesquiere via MapServer-users wrote:
> Dear all,
> Environment :
> Windows : mapmanager, based on MapServer 8.0.1, GDAL 3.8.4
> Linux : MapServer 8.2.0, GDAL 3.8.4
> In order to make my map files more generic, I am using INCLUDE directives.
> When defining a LABEL, I tried to INCLUDE some common definitions. For example :
> MyClass.map file :
> CLASS
>    STYLE
>    END
>    LABEL
>       EXPRESSION ('[NAME]' != 'UNK')
>       TEXT       "[NAME]"
>       INCLUDE    "TextCharacteristics.txt"
>    END
> END
> TextCharacteristics.txt file :
> POSITION CC
> COLOR    "#000000"
> FONT     condensed
> SIZE     12
> I get the following error :
> 'load_Label(): Premature End-of-File. ;msyylex(): Unable to access file.
> Error opening included file "TextCharacteristics.txt"..
> Please correct the issue in the text tab'
> As a workaround, I gave the absolute file path to make it work.
> The documentation says that relative path could be used.
> Did I make something wrong ?
> Thanks for your help
> Philippe
> The information in this e-mail is confidential. The contents may not be disclosed or used by anyone other than the addressee. Access to this e-mail by anyone else is unauthorised.
> If you are not the intended recipient, please notify Airbus immediately and delete this e-mail.
> Airbus cannot accept any responsibility for the accuracy or completeness of this e-mail as it has been sent over public networks. If you have any concerns over the content of this message or its Accuracy or Integrity, please contact Airbus immediately.
> All outgoing e-mails from Airbus are checked using regularly updated virus scanning software but you should take whatever measures you deem to be appropriate to ensure that this message and any attachments are virus free.
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250604/204ae7e1/attachment.htm>
More information about the MapServer-users mailing list
