[MapServer-users] Setting DEBUG file for PHP MapScript in mapserver.conf does not work
Jan Hartmann
j.l.h.hartmann at gmail.com
Thu Mar 20 08:07:42 PDT 2025
Should I submit a bug report, or was this done intentionally?
On 20/03/2025 14:56, Jörg Thomsen (WhereGroup) via MapServer-users wrote:
> Hi Jan,
> I guess the mapserver.conf is not used with mapscript.
>> The configuration file is loaded by the MapServer CGI at runtime and
>> provides site-level configuration for all mapfiles.
> Jörg
> Am 20.03.25 um 14:51 schrieb Jan Hartmann via MapServer-users:
>> Hi,
>> In my mapserver.conf file I have:
>> MS_DEBUGLEVEL "5"
>> MS_ERRORFILE "/var/log/apache2/error.log_mapserver"
>> When calling /cgi-bin/mapserv?map=test.map, I get errors both in the
>> regular apache error log and in the mapserver error log. However,
>> when I use the same map in PHP-MapScript ($oMap = new
>> mapObj("test.map), only the apache error log gets updated. When I
>> configure the mapfile itself both logs get updated:
>> DEBUG 5
>> CONFIG "MS_ERRORFILE" "/var/log/apache2/error.log_mapserver"
>> Is this a bug? I would like to enable debugging for all the Mapscript
>> files in my applications.
>> Jan
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
