[MapServer-users] NULL-EXPRESSION
Björn Danielsson
bjorn.danielsson1946 at outlook.com
Fri Mar 28 03:36:02 PDT 2025
This works for me.
Try this:
Create two layers with the same name and group.
Layer 1 ( takes care of values 2000 and 2100) :
LAYER
NAME "A"
GROUP "A"
PROCESSING 'NATIVE_FILTER=gst IS NOT NULL'
CLASS for 2000
CLASS for 2100
END
Layer 2 ( value = NULL ) ❤️
LAYER
NAME "A"
GROUP "A"
PROCESSING 'NATIVE_FILTER=gst IS NULL'
CLASS for NULL
END
Från: MapServer-users <mapserver-users-bounces at lists.osgeo.org> för Seth G via MapServer-users <mapserver-users at lists.osgeo.org>
Skickat: den 28 mars 2025 10:43
Till: angelique.kroisl at stadt-koeln.de <angelique.kroisl at stadt-koeln.de>; MapServer Users <mapserver-users at lists.osgeo.org>
Ämne: Re: [MapServer-users] NULL-EXPRESSION
Unfortunately, MapServer doesn't have a NULL type.
The workaround is to create a database view or query that will set the NULL to a numeric value of your choosing, e.g. -1 and then use that value in the CLASS expressions.
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social<mailto:geographika at mastodon.social>
On Fri, Mar 28, 2025, at 8:55 AM, Angelique Kroisl via MapServer-users wrote:
Hello,
I'm trying to create a class using the class item "gst."
The attribute in the database can only have three values (2000, 2100, and <NULL>).
Unfortunately, I can't create the NULL EXPRESSION.
I've already tried the following:
EXPRESSION IS NULL
EXPRESSION "<NULL>"
EXPRESSION <NULL>
EXPRESSION EMPTY
What is the correct syntax for this?
Monatlich aktuelle Informationen Ihrer Stadtverwaltung in unserem Newsletter! Newsletter Anmeldung<https://www.stadt-koeln.de/service/onlinedienste/newsletter-anmeldung?para=allgemein>
[https://www.stadt-koeln.de/images/footer-final4-2025.jpg]<https://www.stadt-koeln.de/leben-in-koeln/freizeit-natur-sport/veranstaltungskalender/lidl-final4-dhb-pokal>
MapServer-users mailing list
MapServer-users at lists.osgeo.org<mailto:MapServer-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250328/b120ebf9/attachment-0001.htm>
More information about the MapServer-users
