[MapServer-users] NULL-EXPRESSION
Björn Danielsson
bjorn.danielsson1946 at outlook.com
Sat Mar 29 02:13:30 PDT 2025
It was at least 5 years since I struggled with this.
The map should show a gradient with values like 0, 1-19, 20-39 and so on.
A lot of classes, and I found out that records with a column with null value were returned as value 0 and therefore ended up in
class expression ( x = [0]) together with real values = 0.
That is why I created two layers with the same name as I described in my first mail.
However, if you have no need to differ between 0 and null I think you can either have a class with expression ( x=[0]), or perhaps as Richard G suggested
no expression at all, which would be simplest.
Björn D
Från: MapServer-users <mapserver-users-bounces at lists.osgeo.org> för Richard Greenwood via MapServer-users <mapserver-users at lists.osgeo.org>
Skickat: den 28 mars 2025 16:19
Kopia: angelique.kroisl at stadt-koeln.de <angelique.kroisl at stadt-koeln.de>; MapServer Users <mapserver-users at lists.osgeo.org>
Ämne: Re: [MapServer-users] NULL-EXPRESSION
Have you tried making your CLASS for NULLs the last of the three classes and with no EXPRESSION? The first two classes would pick up 2000 and 2100 and then anything not matching would be in the third class. This works in most cases but I haven't tried it with NULLs.
Rich
On Fri, Mar 28, 2025 at 4:36 AM Björn Danielsson via MapServer-users <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>> wrote:
This works for me.
Try this:
Create two layers with the same name and group.
Layer 1 ( takes care of values 2000 and 2100) :
LAYER
NAME "A"
GROUP "A"
PROCESSING 'NATIVE_FILTER=gst IS NOT NULL'
CLASS for 2000
CLASS for 2100
END
Layer 2 ( value = NULL ) ❤️
LAYER
NAME "A"
GROUP "A"
PROCESSING 'NATIVE_FILTER=gst IS NULL'
CLASS for NULL
END
Från: MapServer-users <mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>> för Seth G via MapServer-users <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Skickat: den 28 mars 2025 10:43
Till: angelique.kroisl at stadt-koeln.de<mailto:angelique.kroisl at stadt-koeln.de> <angelique.kroisl at stadt-koeln.de<mailto:angelique.kroisl at stadt-koeln.de>>; MapServer Users <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Unfortunately, MapServer doesn't have a NULL type.
The workaround is to create a database view or query that will set the NULL to a numeric value of your choosing, e.g. -1 and then use that value in the CLASS expressions.
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social<mailto:geographika at mastodon.social>
On Fri, Mar 28, 2025, at 8:55 AM, Angelique Kroisl via MapServer-users wrote:
Hello,
I'm trying to create a class using the class item "gst."
The attribute in the database can only have three values (2000, 2100, and <NULL>).
Unfortunately, I can't create the NULL EXPRESSION.
I've already tried the following:
EXPRESSION IS NULL
EXPRESSION "<NULL>"
EXPRESSION <NULL>
EXPRESSION EMPTY
What is the correct syntax for this?
Monatlich aktuelle Informationen Ihrer Stadtverwaltung in unserem Newsletter! Newsletter Anmeldung<https://www.stadt-koeln.de/service/onlinedienste/newsletter-anmeldung?para=allgemein>
[X]<https://www.stadt-koeln.de/leben-in-koeln/freizeit-natur-sport/veranstaltungskalender/lidl-final4-dhb-pokal>
MapServer-users mailing list
MapServer-users at lists.osgeo.org<mailto:MapServer-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
Richard W. Greenwood
www.greenwoodmap.com<http://www.greenwoodmap.com>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20250329/3f7a7368/attachment-0001.htm>
More information about the MapServer-users
