[MapServer-users] How to use SLD generated from CLASS and how to use STYLEITEM with sld
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Thu May 8 04:46:02 PDT 2025
I cannot say what makes trouble for you, but like this it should work:
https://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetStyles&layers=continents
-Jukka Rahkonen-
________________________________________
Lähettäjä: MapServer-users käyttäjän Trygve Aspenes via MapServer-users puolesta
Lähetetty: Torstai 8. toukokuuta 2025 14.21
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [MapServer-users] How to use SLD generated from CLASS and how to use STYLEITEM with sld
I'm looking at SLD with mapserver 8.4.0
I think I read somewhere in the docs that mapserver can generate SLD
from a layer defined class. Not sure if this is correct. I try with my
test with GetStyles like this:
curl
'http://localhost:8091/okd?version=1.3.0&service=wms&request=getstyles&layers=TestLayer'
But this gives me:
<StyledLayerDescriptor version="1.1.0"
xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd"
xmlns="http://www.opengis.net/sld"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:se="http://www.opengis.net/se"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
</StyledLayerDescriptor>
So it is a valid SLD, but with no actual content
The layer part in my mapfile looks like this:
     LAYER
         NAME "TestLayer"
         TYPE RASTER
         STATUS ON
         METADATA
             "ows_sld_enabled" "true"
             "SLD_USE_FIRST_NAMEDLAYER" "true"
         END
         DATA "<raster data>"
         PROJECTION
            <some projection>
         END
         METADATA
             "wms_title" "Test Layer"
             "wms_srs" "EPSG:3857 EPSG:4326"
         END
         CLASS
             NAME " 0 -  3"
             GROUP "value"
             EXPRESSION ([pixel]>=0.0 and [pixel]<3.0)
             STYLE
                 COLOR 221 95 77
             END # STYLE
         END # CLASS
         <Some more classes>
      END
Then I try to remove the CLASS definitions and add STYLEITEM with and
sld document like this:
     LAYER
         NAME "TestLayer"
         TYPE RASTER
         STATUS ON
         STYLEITEM "sld://sld-test.xml" #Using the example of the latest
docs p 873-874>
         METADATA
         END
         PROJECTION
            <some projection>
         END
         METADATA
         END
      END
But still the same response with the GetStyles request as above.
What am I missing here? Any ideas?
mapserv -v says: MapServer version 8.4.0 PROJ version 9.4 GDAL version
3.8 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER SUPPORTS=OGCAPI_SERVER
SUPPORTS=FASTCGI SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE INPUT=FLATGEOBUF
Trygve
MapServer-users mailing list
MapServer-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
