[MapServer-users] How do I get rid of the WMS option?
Seth G sethg at geographika.co.uk
Thu May 8 06:39:55 PDT 2025
I don't think GetMetadata is specific to WMS, but is common to all the WxS services.
It should have been possible to disable it using something like the following in METADATA, but after a quick look at the code it doesn't appear to be implemented:
"ows_enable_request" "* !GetMetadata"
MapServer only generates XML. If you want to use another format the following METADATA should work:
"ows_metadataurl_href" "http://example.com/my.json"
Maybe the following also disables it?
"ows_metadataurl_href" "" # try a blank URL?
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Wed, May 7, 2025, at 3:21 PM, Stefan Gofferje via MapServer-users wrote:
> Hi again,
> so I have configured a MapServer map without any WMS configuration but
> MapServer is still offering WMS in the reply to GetMetaData.
> s.
> https://ms.saakeskus.fi/?map=wfs&request=GetMetadata&layer=fmimeasurements
> It also only offers GML2 and GML3 although I have configured GeoJSON via
> an OUTPUTFORMAT block in the map file and it also works if I add
> OUTPUTFORMAT=geojson to the URL.
> Any hints on what's the problem?
> -Stefan
>   (o_   Stefan Gofferje            | SCLT, MCP, CCSA
>   //\   Reg'd Linux User #247167   | VCP #2263
>   V_/_  https://www.gofferje.net   | https://www.saakeskus.fi
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
