[MapServer-users] WMS with a GPKG-based layer : different responses, dependending on version (1.1.1 vs 1.3.0)
Philippe Ghesquiere philippe.ghesquiere at airbus.com
Wed Feb 18 01:37:52 PST 2026
Hi all,
*1) Problem description:*
Our system is offering an OSM layer, based on a WGS84 GPKG (Z=0 to Z=13).
I sent two WMS requests, where the only difference is the standard version :
   - WMS V1.1.1 request:
   https://xxx/layers/baselayers/wms?service=WMS&version=1.1.1&request=GetMap&Layers=osm_4326&Styles=&SRS=EPSG:4326&Format=image/png&BBOX=45,22.5,67.5,45&Width=1024&Height=1024
   - WMS V1.3.0 request:
   https://xxx/layers/baselayers/wms?service=WMS&version=1.3.0&request=GetMap&Layers=osm_4326&Styles=&CRS=EPSG:4326&Format=image/png&BBOX=22.5,45,45,67.5&Width=1024&Height=1024
  I observe some differences :
   - V1.1.1: https://pasteboard.co/JjKbU4yvSxrM.png,
   Labels are easy to read: mapcache/mapserver is selecting the right zoom
   level in the GPKG file.
   - V1.3.0: https://pasteboard.co/XzpHSJjSTiQV.png.
   Labels are much too small and not readable. It seems that
   mapcache/mapserver is selecting a higher zoom level than expected
   and down-sample the image.
I do not understand why the rendering is not the same.
As far as I know, WMS requests do not have standard parameters which give a
*direct* access to zoom layer, resolution or DPI.
I tried to add some parameters to my request, with no impact on the
response:
   - DPI=240
   - MAP_RESOLUTION=240
   - FORMAT_OPTIONS=dpi:240.
I also tried to add parameters in the "MAP block":
   - RESOLUTION
   - DEFRESOLUTION
*2) Software environment:*
Mapserver 8.2.0
Mapcache 1.14.0
Gdal V3.8.4
Alma Linux V8
*3) Map file excerpt*
MAP
    NAME "baselayers_wms"
    STATUS ON
    SIZE 256 256
    EXTENT -180.0 -90.0 180.0 90.0
    UNITS dd
#    DEFRESOLUTION 200
#    RESOLUTION  144
    PROJECTION
        "init=epsg:4326"
    END
*4) My questions:*
Why do I get different responses between V1.1.1 and V1.3.0 WMS requests ?
Are there any configuration parameters which have default values in one
version and not in the other ?
I would be glad to have some hints to get better WMS 1.3.0 responses
Sincerely
Philippe
The information in this e-mail is confidential. The contents may not be disclosed or used by anyone other than the addressee. Access to this e-mail by anyone else is unauthorised.
If you are not the intended recipient, please notify Airbus immediately and delete this e-mail.
Airbus cannot accept any responsibility for the accuracy or completeness of this e-mail as it has been sent over public networks. If you have any concerns over the content of this message or its Accuracy or Integrity, please contact Airbus immediately.
All outgoing e-mails from Airbus are checked using regularly updated virus scanning software but you should take whatever measures you deem to be appropriate to ensure that this message and any attachments are virus free.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20260218/aed4e2bc/attachment.htm>
More information about the MapServer-users mailing list
