[MapServer-users] WMS with a GPKG-based layer : different responses, dependending on version (1.1.1 vs 1.3.0)
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Thu Feb 19 10:32:09 PST 2026
Thank you very much for the information, now I start to understand. It seems that you have done everything right. Maybe it is GDAL who thinks that the closest resolution comes from another zoom level when the axis swap happens. I am not sure yet how to test that, but I am still thinking.
I suppose that your Mapserver and MapCache are not on the same machine, otherwise you could use osm_4326.gpkg directly in the mapfile LAYER-DATA without going through MapCache and WMTS. And you don't want to serve WMS from MapCache, even it should be able to do it with both versions https://mapserver.org/mapcache/services.html#ogc-wms-service. Is that right?
-Jukka Rahkonen-
________________________________________
Lähettäjä: Philippe Ghesquiere <philippe.ghesquiere at airbus.com>
Lähetetty: Torstai 19. helmikuuta 2026 19.04
Vastaanottaja: Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Kopio: MapServer Users <mapserver-users at lists.osgeo.org>
Aihe: Fwd: [MapServer-users] WMS with a GPKG-based layer : different responses, dependending on version (1.1.1 vs 1.3.0)
Hi Jukka,Our GPKG (osm_4326.gpkg) contains OSM tiles, with an InspireCRS84Quad tiling scheme. The pyramid goes from Z=0 down to Z=13.In the Mapfile, the layer's DATA is coming from the MapCache WMTS layer (i.e. the GPKG file).Mapfile excerpt :LAYER   NAME "osm_4326"   METADATA     "wms_title" "OpenStreet Map WMS"   END   TYPE RASTER   DATA "baselayers_gdal_osm.xml"   PROJECTION      "init=epsg:4326"   ENDENDbaselayers_gdal_osm.xml content:<GDAL_WMTS>   <GetCapabilitiesUrl>http://localhost/mapcache/wmts?request=GetCapabilities&SERVICE=WMTS</GetCapabilitiesUrl>   <Layer>osm_4326</Layer>   <Style>default</Style>   <TileMatrixSet>WGS84</TileMatrixSet>   <DataWindow>      <UpperLeftX>-180.0</UpperLeftX>      <UpperLeftY>90.0</UpperLeftY>      <LowerRightX>180.0</LowerRightX>      <LowerRightY>-90.0</LowerRightY>   </DataWindow>   <BandsCount>4</BandsCount>   <Cache/>   <UnsafeSSL>true</UnsafeSSL>   <ZeroBlockHttpCodes>204,404</ZeroBlockHttpCodes>   <ZeroBlockOnServerException>true</ZeroBlockOnServerException></GDAL_WMTS>WMTS cache definition:<cache name="osm_cache_4326" type="sqlite3">    <dbfile>/xxx/osm_4326.gpkg</dbfile>    <queries>       <get>select tile_data from tiles where tile_column=:x and tile_row=:inv_y and zoom_level=:z</get>    </queries></cache><tileset name="osm_4326">    <cache>osm_cache_4326</cache>    <grid restricted_extent="-180.0,-90.0,180.0,90.0">WGS84</grid>    <format>PNG</format>    <metadata>       <title>OSM (Fond de carte) WGS84</title>    </metadata></tileset>PhilippeThe information in this e-mail is confidential. The contents may not be disclosed or used by anyone other than the addressee. Access to this e-mail by anyone else is unauthorised.If you are not the intended recipient, please notify Airbus immediately and delete this e-mail.Airbus cannot accept any responsibility for the accuracy or completeness of this e-mail as it has been sent over public networks. If you have any concerns over the content of this message or its Accuracy or Integrity, please contact Airbus immediately.All outgoing e-mails from Airbus are checked using regularly updated virus scanning software but you should take whatever measures you deem to be appropriate to ensure that this message and any attachments are virus free.
More information about the MapServer-users mailing list
