[MapServer-users] Issue with line colors in mapserver 8.4.0
Linsenmaier, Dierk Dierk.Linsenmaier at regiodata-gmbh.de
Tue Jan 13 00:29:35 PST 2026
Hello mapserver community,
Since we switched from mapserver version 7.6.4 to version 8.4.0, I have an issue with colors in line layers.
All dynamic color definitions (color is defined by a variable) are rendered with the same color. No matter if we use RGB- or HEX-Color values.
COLOR [VAR]
The values for the color  variable are defined by  an oracle SQL querry.
Example SQL:
DATA                    "geom FROM (SELECT id,status,zeitraum,   case   when Zeitraum in ( 2023) then '166 206 227'  when Zeitraum in ( 2024) then '31 120 180' when Zeitraum in ( 2025) then '227 26 28' when Zeitraum in ( 2026) the
n '255 127 0' when Zeitraum in ( 2027) then '253 191 111' when Zeitraum in ( 2028,2029,2030) then '251 154 153' when Zeitraum in ( 2031,2032,2033,2034,2035) then '51 160 44' when Zeitraum in ( 2036,2037,2038,2039,2040) then '178 223 138'
END  as color, geom,'Status: '||STATUS__LL||'</BR>Trassenlänge: '||trassenlaenge||'m' AS banner FROM my_oracle_table WHERE 1=1  ) USING UNIQUE ID SRID 25832 FILTER"
CLASS definition:
        CLASS
                NAME            "CLASS 1"
                EXPRESSION ("[STATUS]" IN "in_ausfuehrung")
                STYLE
                        OPACITY                 90
                        OUTLINECOLOR    255 255 255
                        WIDTH                   7
                        LINECAP butt
                END#STYLE
                STYLE
                        OPACITY                 100
                        COLOR                   [COLOR]#28 22 63
                        WIDTH                   4
                        LINECAP butt
                END #STYLE
        END #CLASS
        CLASS
                NAME            "CLASS 2"
                EXPRESSION ("[STATUS]" IN "geplant_genehm_gut")
                STYLE
                        OPACITY                 90
                        WIDTH                   7
                        LINECAP butt
                END#STYLE
                STYLE
                        OPACITY                 100
                        PATTERN                   12 6 12 6 END
                        WIDTH                   4
                        LINECAP butt
                END #STYLE
        END #CLASS
        CLASS
                NAME            "CLASS 3"
                EXPRESSION ("[STATUS]" IN "geplant_n_genehm")
                STYLE
                        OPACITY                 90
                        WIDTH                   7
                        LINECAP butt
                END#STYLE
                STYLE
                        OPACITY                 100
                        PATTERN                   12 6 4 6 END
                        WIDTH                   4
                        LINECAP butt
                END #STYLE
        END #CLASS
Is this a know issue or do you have any hint for me to solve it?
Mit freundlichen Grüßen
Dierk Linsenmaier
Dierk Linsenmaier
Team GIS
Informationstechnik
regioDATA
Tullastr. 61
79108 Freiburg i. Brsg.
Telefon  07621 91943-477
Telefax   07621 91943-465
dierk.linsenmaier at regiodata-gmbh.de
www.regiodata-gmbh.de
regioDATA GmbH
Sitz Lörrach, Amtsgericht Freiburg HRB 412719
Geschäftsführer: Michael Schade
More information about the MapServer-users mailing list
