[MapServer-users] LAYER TOLERANCE increases requested OGC API bbox
Seth G sethg at geographika.co.uk
Fri Jun 19 05:52:39 PDT 2026
Hi Killian,
This seems like an oversight, as for WFS MapServer explicity sets the TOLERANCE to 0 [1].
The same should be done for OGC Features. Could you raise an issue for this at https://github.com/MapServer/MapServer/issues?
Thanks,
Seth
[1] https://github.com/MapServer/MapServer/blob/abaa114c6973cc67cacd82e8a724f994a00eb785/src/mapwfs.cpp#L3016
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Tue, Jun 16, 2026, at 11:42 AM, Kilian Glaus via MapServer-users wrote:
> Hello everybody
> If I have a defined TOLERANCE on the LAYER level of a mapfile, the requested bbox of an OGC API request is increased linear with the size of TOLERANCE. Is this intended or a bug?
> The problem occurs with another EPSG like 4326
> When I do a WFS request with the same bbox, the TOLERANCE is ignored.
> *Request:* `/ogcapi/collections/prozessraum_rutschung/items?f=json&bbox=2678483.5005230373,1286876.7365089145,2680778.0675097415,1287676.7148341944&bbox-crs=http://www.opengis.net/def/crs/EPSG/0/2056`
> *Request without TOLERANCE*
> *Processed BBOX:* POLYGON((2678472.83748642 1286845.70388825,2678472.83748642 1287707.7538654,2680789.0451681 1287707.7538654,2680789.0451681 1286845.70388825,2678472.83748642 1286845.70388825))
> *Request with TOLERANCE 4*
> *Processed BBOX: *POLYGON((2670889.86292488 1275708.25617677,2670889.86292488 1298857.60050378,2688405.20300468 1298857.60050378,2688405.20300468 1275708.25617677,2670889.86292488 1275708.25617677))
> *Request with TOLERANCE 8*
> *Processed BBOX: *POLYGON((2663334.74802645 1264580.34909246,2663334.74802645 1310016.9403732,2696049.18633325 1310016.9403732,2696049.18633325 1264580.34909246,2663334.74802645 1264580.34909246))
> Best regards
> Kilian
> __
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20260619/4dd9689a/attachment-0001.htm>
More information about the MapServer-users mailing list
