[MDAL-Developer] MDAL, Python and QGIS
Paul Harwood
runette at gmail.com
Fri Dec 2 01:17:12 PST 2022
I had a look at the mdal provider and it does not seem to expose any
mdal symbols.
Paul
On Fri, 2 Dec 2022 at 06:58, Peter Petrik <
peter.petrik at lutraconsulting.co.uk> wrote:
> Hi,
> I am wondering if mdal provider does not expose the symbols too, so you
> can use it instead of mdal.dll?
> Kind Regards,
> Peter Petrík
> CPO of Mergin Maps
> LI <https://www.linkedin.com/in/peter-petrik/>, Mergin Maps
> <https://www.merginmaps.com>
> On Thu, Dec 1, 2022 at 11:13 PM Martin Dobias <wonder.sk at gmail.com> wrote:
>> Hi Paul
>> On Thu, Dec 1, 2022 at 2:05 PM Paul Harwood <runette at gmail.com> wrote:
>>> The current state is that `pip install mdal-python` can be used in the
>>> OSGEO shell and works correctly and the Python bindings package is then
>>> accessible in the Python Console but it does not work because MDAL (in the
>>> form of mdal.dll / libmdal.so / libmdal.dylib) is not installed in QGIS.
>>> I thought that QGIS was using MDAL but I guess it is installed in a
>>> different way.
>>> Does anyone know how this can be addressed?
>> QGIS uses its own copy of MDAL and by default the library is built into
>> the mdal provider module, that's why there's no mdal.dll or equivalent. It
>> is also possible to compile QGIS with a custom MDAL library, but because
>> has not been spread much outside of QGIS, using the internal copy makes
>> things simpler.
>> I can imagine that if there would be demand for it, the OSGeo4W packaging
>> could be updated so that MDAL would be compiled and shipped as a separate
>> package with a dedicated mdal.dll - that's something to raise with the
>> OSGeo4W maintainers I guess...
>> Regards
>> Martin
>> MDAL-Developer mailing list
>> MDAL-Developer at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mdal-developer
URL: <http://lists.osgeo.org/pipermail/mdal-developer/attachments/20221202/275411c0/attachment.htm>
More information about the MDAL-Developer
