[Mobilitydb-dev] Update about my experiments integrating PostGIS 3.1.3 and MobilityDB
Vicky Vergara
vicky at georepublic.de
Mon Aug 23 09:41:50 PDT 2021
Yeah, I have that problem also when testing on different
platforms/compilers/postgres
But I resolved by using on some tests that were having precision problems
with:
SET extra_float_digits = -3;
https://github.com/pgRouting/pgrouting/blob/main/pgtap/withPoints/withPoints_oneToOne-compare-dijkstra.test.sql#L30
Documentation about that can be found here:
https://www.postgresql.org/docs/12/datatype-numeric.html
In another case I had to resolve floating point comparison internally with:
https://github.com/pgRouting/pgrouting/blob/main/src/common/xy_vertex.cpp#L36
Which I got from here:
https://en.cppreference.com/w/cpp/types/numeric_limits/epsilon
Allways keep in mind floating point
Remember for example that:
mathematically: 1 == 1/3 + 1/3 + 1/3
But computationally: 1 != 1/3 + 1/3 + 1/3
The reason is floating point
I like this article
https://randomascii.wordpress.com/2012/02/25/comparing-floating-point-numbers-2012-edition/
On Sun, Aug 22, 2021 at 7:56 AM Esteban Zimanyi <estebanzimanyi at gmail.com>
wrote:
> Dear Vicky and Regina
> Following the recommendations we received at the PostGIS Dev meeting this
> August 20, I started to experiment the embedding of liblwgeom from PostGIS
> 3.1.3 inside MobilityDB. I was able to run the MobilityDB tests but
> obviously things have changed from versions 2.5.5 to 3.1.3.
> You will find enclosed a diff of the results of one of the tests. As you
> can see there are two types of differences. The first one concerns a very
> small floating point precision difference, e.g.,
> SELECT ST_AsText(trajectory(tnpoint 'Npoint(1, 0.5)@2000-01-01'));
> - st_astext
> - POINT(48.71866291282778 77.76407051015086)
> + st_astext
> + POINT(48.7186629128278 77.7640705101509)
> (1 row)
> Another type of error concerns deprecated functions
> SELECT setPrecision(atGeometry(tnpoint '{Npoint(1, 0.3)@2000-01-01,
> Npoint(1, 0.5)@2000-01-02, Npoint(1, 0.5)@2000-01-03}', geometry
> 'SRID=5676;Polygon((50 50,50 100,100 100,100 50,50 50))'), 6);
> -ERROR
> -DETAIL: Library function 'intersects' was deprecated in PostGIS 3.0.0
> -HINT: Consider running: SELECT postgis_extensions_upgrade()
> + setprecision
> + {NPoint(1,0.3)@2000-01-01 00:00:00+00}
> +(1 row)
> In the forthcoming days I will be modifying the develop branch so that the
> tests can be run in both versions PostGIS 2.5.5 and 3.1.3.
> Furthermore, as a consequence of the problem I reported on the ticket
> https://trac.osgeo.org/postgis/ticket/4979#comment:5
> it is not possible to mix PostGIS 2.5.5 and 3.1.3 (e.g., use liblwgeom.so
> from PostGIS 2.5.5 with PostGIS 3.1.3 which was one of the tests planned)
> since all the lwgeom struct definitions have been changed.
> Regards
> Esteban
> Prof. Esteban Zimanyi
> Department of Computer & Decision Engineering (CoDE) CP 165/15
> Universite Libre de Bruxelles
> Avenue F. D. Roosevelt 50
> B-1050 Brussels, Belgium
> fax: + 32.2.650.47.13
> tel: + 32.2.650.31.85
> e-mail: esteban.zimanyi at ulb.be
> Internet: http://cs.ulb.ac.be/members/esteban/
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20210823/febb93c3/attachment.html>
More information about the Mobilitydb-dev
