[Mobilitydb-dev] The standard
Esteban Zimanyi esteban.zimanyi at ulb.be
Tue Aug 24 07:51:33 PDT 2021
The starting point is the ISO standard
https://www.iso.org/standard/41445.html
from which the other OGC standards are derived from
https://www.ogc.org/standards/movingfeatures
After our implementation of these standards in MobilityDB we found out
several issues and potential improvements that we are currently discussing
within the OGC SWG. In particular,
* An extension of the WKB format is needed for an efficient data exchange
between applications. This is required, e.g., in a distributed Cloud
environment where each node has only a subset of the dataset. Performing
distributed joins requires that data be exchanged between nodes (a.k.a.
reshuffling). This has been presented in the following presentation
https://docs.mobilitydb.com/pub/WKB-OGC-2021-June-slides.pdf
* The encoding standards are not semantically equivalent, we discussed that
in the following paper
https://arxiv.org/abs/2006.16900
Regards
Esteban
On Tue, Aug 24, 2021 at 4:26 PM Paragon Corporation <lr at pcorp.us> wrote:
> https://www.ogc.org/projects/groups/movfeatswg
> This one I believe.
> On Tue, Aug 24, 2021 at 10:19 AM Vicky Vergara <vicky at georepublic.de>
> wrote:
>> Hello all
>> Can you point to me in the right direction to read the OGC standard that
>> MobilityDB follows.
>> Thanks Vicky
>> Georepublic UG (haftungsbeschränkt)
>> Salzmannstraße 44,
>> 81739 München, Germany
>> Vicky Vergara
>> Operations Research
>> eMail: vicky at georepublic.de
>> Web: https://georepublic.info
>> Tel: +49 (089) 4161 7698-1
>> Fax: +49 (089) 4161 7698-9
>> Commercial register: Amtsgericht München, HRB 181428
>> CEO: Daniel Kastl
>> Mobilitydb-dev mailing list
>> Mobilitydb-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mobilitydb-dev
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20210824/cdc7a58b/attachment-0001.html>
More information about the Mobilitydb-dev mailing list
