[Mobilitydb-dev] Instructions for building MobilityDB on Windows with msys2
Esteban Zimanyi
esteban.zimanyi at ulb.be
Wed Sep 8 23:02:06 PDT 2021
Thanks a lot Regina for these detailed explanations !
I will try building from them and let you know the outcome.
On Wed, Sep 8, 2021 at 5:53 PM Regina Obe <lr at pcorp.us> wrote:
> Esteban,
> Unfortunately I don’t build that way more about the particulars of what I
> work on (I have to build for many versions of PostGIS and PostgreSQL) than
> anything wrong with your below instructions.
> So I wouldn’t be able to easily validate. At a glance they look fine.
> This much I can say.
> I do build PostgreSQL using mingw/msys2 tool chain (I don’t use the
> PostgreSQL VC++ standard builds for building – mostly because of the
> hassle of making it work the way it does on Linux – and I need autotools
> for building PostGIS).
> I do however test against both mingw install and the PostgreSQL VC++
> standard builds (using EDB zip binaries -
> https://www.enterprisedb.com/download-postgresql-binaries ).
> For testing pgRouting/PostGIS against PostgreSQL VC++ I just start up that
> instance copy the mingw compiled binaries and extension files to the VC
> build and run the tests.
> In your case since you are building with CMake – you could possibly work
> with either mode. pgRouting for example builds fine for windows both
> against my mingw setup and standard VC++ setup -
> https://github.com/pgRouting/pgrouting/blob/main/.github/workflows/windows.yml
> (uses standard VC++ setup)
> I also use Msys cmake for building. This might not be necessary anymore
> but when I started up building with CMake I had horrible experience with
> things just not working with the Cmake packaged with msys-mingw, so I
> always downloaded the windows cmake binaries from
> https://cmake.org/download/ (the 32-bit cause I had to build for both
> 64-bit and 32-bit) and then using:
> cmake -G "MSYS Makefiles"
> That also allowed me to easily test the (latest or particular version of)
> cmake system without disrupting my msys/mingw setup.
> *From:* Mobilitydb-dev [mailto:mobilitydb-dev-bounces at lists.osgeo.org] *On
> Behalf Of *Esteban Zimanyi
> *Sent:* Wednesday, September 8, 2021 11:24 AM
> *To:* mobilitydb-dev at lists.osgeo.org
> *Subject:* [Mobilitydb-dev] Instructions for building MobilityDB on
> Windows with msys2
> Dear Regina & Vicky
> We have tested the instructions below for building MobilityDB on Windows
> with msys2 and they work on arbitrary machines.
> However, while I have already PostgreSQL and PostGIS installed on my
> Windows computer, the instructions below reinstall PostgreSQL and PostGIS
> on msys2 and build with those versions instead of the already installed
> ones.
> Can you tell us whether this is the right way to do the build or how we
> can improve it ?
> Many thanks for your help
> Download the msys2 installer from https://www.msys2.org/ and follow the
> instructions. In the following we assume that you install msys2 on drive D:
> On the MSYS2 MSYS shell run the following commands to install the required
> dependencies
> pacman -S mingw-w64-x86_64-cmake mingw-w64-x86_64-postgresql
> mingw-w64-x86_64-postgis
> pacman -S mingw-w64-x86_64-gsl mingw-w64-i686-xz git
> Run "MSYS MinGW 64-bit" from Start menu and run the following commands
> git clone https://github.com/estebanzimanyi/MobilityDB.git
> cd MobilityDB
> mkdir build
> cd build
> git checkout msys2-build
> cmake -DCMAKE_BUILD_TYPE=Release -G"MinGW Makefiles" ..
> cmake --build .
> cmake --install .
> You need to define where the databases will reside on your hard disk. In
> the following we assume the location D:/msys64/usr/local/pgsql/data. Run
> export PGDATA="D:/msys64/usr/local/pgsql/data"
> rm -rf $PGDATA # DANGER ! This remove all existing databases in that
> directory
> initdb
> To start the database you need to define the port used by PostgreSQL to
> listen for connections from client applications. This is typically 5432
> unless you have other PostgreSQL versions installed. On msys2 you can use
> the following command to see the ports already in use
> netstat -a -o | grep LISTENING
> In the following we assume that we use the port 5433. Then issue the
> following command
> export PGPORT=5433
> pg_ctl start
> createdb mydb
> psql mydb
> Now on psql issue the following commands
> CREATE EXTENSION mobilitydb CASCADE;
> SELECT mobilitydb_version();
> You should see something like the following
> mobilitydb_full_version
> MobilityDB 1.0.0 Beta 3, PostgreSQL 13.3, PostGIS 2.5.5
> (1 row)
> You are now ready to use MobilityDB !
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20210909/0ad0c5fa/attachment.html>
More information about the Mobilitydb-dev
