[Mobilitydb-dev] Fwd: [PostGIS] #4992: Problem with ST_FrechetDistance in PostGIS/GEOS ?
Esteban Zimanyi
esteban.zimanyi at ulb.be
Thu Sep 16 13:59:46 PDT 2021
Answer from Martin Davis
https://www.linkedin.com/in/mrmartindavis/?originalSubdomain=ca
https://github.com/dr-jts
---------- Forwarded message ---------
Date: Thu, Sep 16, 2021 at 10:48 PM
Subject: Re: [PostGIS] #4992: Problem with ST_FrechetDistance in
PostGIS/GEOS ?
To:
Cc: <postgis-tickets at lists.osgeo.org>
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.5
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by mdavis):
Perhaps you have a more "batteries include" implementation of Frechet
Distance.
The PostGIS algorithm (coming from GEOS) is a Discrete Frechet Distance
implementation. It works better if the geometry is densified via the
optional third argument:
SELECT ST_FrechetDistance(
'Linestring(1 1,2 2,3 1)',
'Linestring(1 4,2 3,3 4,4 3)', .01);
st_frechetdistance
2.9800000000000004
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4992#comment:1>
The PostGIS Trac is used for bug, enhancement & task tracking, a user and
developer wiki, and a view into the subversion code repository of PostGIS
project.
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20210916/424a173a/attachment.html>
More information about the Mobilitydb-dev
