[Mobilitydb-dev] intersection of tgeompoint with a geometry and period
Esteban Zimanyi
estebanzimanyi at gmail.com
Fri Jul 1 09:22:29 PDT 2022
Dear Wendell
What about doing
tintersects(atPeriod(flown_path, period), boundary)
The atPeriod function will reduce the number of points (or produce an empty
result if there is no overlap between the periods of the flights and the
boundary) which will speed up the tintersects function which is expensive.
The geometric intersection is actually done by GEOS and then from this
result MobilityDB needs to compute back the timestamps of the intersections.
Please let me know if this works for you.
Regards
Esteban
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20220701/b719e57a/attachment.htm>
More information about the Mobilitydb-dev
