[Mobilitydb-dev] version info in dx?
Wendell Turner WTurner at cssiinc.com
Wed Jul 13 16:37:00 PDT 2022
Would it be possible to tag the 'develop' branch of the MobilityDB repo with a different tag?  On a system that is running the 'develop' branch, the \dx command in psql still shows '1.0.0' :
filedflown=# \dx
                                            List of installed extensions
        Name        | Version |   Schema   |                              Description
 mobilitydb         | 1.0.0   | public     | MobilityDB Extension
 postgis            | 3.2.1   | public     | PostGIS geometry and geography spatial types and functions
I have several databases with several versions of things, and it would be nice to use the dx command to show which version of MobilityDB was running on each installation.
Also, it would be helpful if that number were to change when the postgresql table format changes.  (Maybe the minor version could be used to indicate those changes?  That is, if the current develop branch were tagged '1.1' or '1.1.0-rc1' it could not be (mistakenly) installed on a system with tables that were built using a 1.0 version.)
Thank you,
Wendell
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20220713/239a5b93/attachment.htm>
More information about the Mobilitydb-dev mailing list
