[Mobilitydb-dev] Configuring for a Particular PostgreSQL on Ubuntu
Regina Obe
lr at pcorp.us
Sun May 22 12:12:37 PDT 2022
I have multiple versions of PostgreSQL installed on my Ubuntu server.
I can't figure out how to install against a particular version.
I've tried this:
cd MobilityDB
export PGVER=14
export PGPATH=/usr/lib/postgresql/${PGVER}
export PATH=$PATH:/usr/lib/postgresql/${PGVER}/bin
rm -rf build
mkdir build
cd build
cmake -DPOSTGRES_PG_CONFIG=$PGPATH/bin/pg_config ..
and I tried this:
cd MobilityDB
export PGVER=14
rm -rf build
mkdir build
cd build
#I also explicitly tried setting the POSTGRESQL_BIN_DIR via cmake.
Regardless what I do it still outputs:
-- POSTGRESQL_VERSION_MAJOR=15
-- POSTGRESQL_VERSION_MINOR=0
-- POSTGRESQL_BIN_DIR: /usr/lib/postgresql/15/bin
-- POSTGRESQL_INCLUDE_DIR: /usr/include/postgresql/15/server
-- POSTGRESQL_LIBRARIES: /usr/lib/aarch64-linux-gnu
-- POSTGRESQL_SHARE_DIR: /usr/share/postgresql/15
-- POSTGRESQL_DYNLIB_DIR: /usr/lib/postgresql/15/lib
-- POSTGRESQL_VERSION: 15.0
As I mentioned in this issue, mobilitydb does not work against PostgreSQL 15
https://github.com/MobilityDB/MobilityDB/issues/218
Thanks,
Regina
More information about the Mobilitydb-dev
