[Mobilitydb-dev] question regarding the database schema
SAKR Mahmoud
mahmoud.sakr at ulb.be
Mon Oct 30 14:15:30 PDT 2023
Have a look at the different workshops. Specially the AIS workshop will show a similar example as your case:
https://mobilitydb.github.io/MobilityDB-workshop/develop/html/index.html
Best regards,
Mahmoud SAKR
From: Mobilitydb-dev <mobilitydb-dev-bounces at lists.osgeo.org> on behalf of Manda Awad via Mobilitydb-dev <mobilitydb-dev at lists.osgeo.org>
Sent: Wednesday, October 11, 2023 10:21 AM
To: mobilitydb-dev at lists.osgeo.org <mobilitydb-dev at lists.osgeo.org>
Subject: [Mobilitydb-dev] question regarding the database schema
Hello team,
I hope you are doing well.
I am reaching out to ask you about the best way to store data in mobilitydb, I have a lot of telematics data for example (fuel level, acceleration readings, rpm, braking is active, .....) and many more, what is the best way to store these data in mobilitydb?
Thanks! Regards
Manda Awad
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20231030/d458157d/attachment.htm>
More information about the Mobilitydb-dev
