[Mobilitydb-dev] Coordinated Vulnerability Disclosure - MobilityDB / MobilityDB
Esteban Zimanyi
estebanzimanyi at gmail.com
Tue Sep 29 10:03:27 PDT 2026
Hello,
Thank you for reserving CVE-2026-102639 and for the draft record, which is
accurate. The fix is now published, and we would ask for these changes:
1. Affected versions: 1.1.0 through 1.1.2 (no fix is planned for the 1.1
series), 1.2.0 before 1.2.2, and 1.3.0 before 1.3.1. The fixed releases are
1.2.2 and 1.3.1.
2. References:
https://github.com/MobilityDB/MobilityDB/security/advisories/GHSA-2c92-2w7c-pm3g
- https://github.com/MobilityDB/MobilityDB/releases/tag/v1.3.1
- https://github.com/MobilityDB/MobilityDB/releases/tag/v1.2.2
- https://github.com/MobilityDB/MobilityDB/pull/2867
- https://github.com/MobilityDB/MobilityDB/pull/2865
- https://github.com/MobilityDB/MobilityDB/pull/2866
3. Title: "MobilityDB through 1.3.0 Out-of-bounds Read DoS via WKB
Deserialization".
4. Description: the same flaw also affects applications that link the MEOS
library and read untrusted WKB.
Best regards,
Esteban
Prof. Esteban Zimanyi
Department of Computer & Decision Engineering (CoDE) CP 165/15
Universite Libre de Bruxelles
Avenue F. D. Roosevelt 50
B-1050 Brussels, Belgium
fax: + 32.2.650.47.13
tel: + 32.2.650.31.85
e-mail: esteban.zimanyi at ulb.be
Internet: http://cs.ulb.ac.be/members/esteban/
On Tue, Sep 29, 2026 at 5:57 PM Brandon Tarr <btarr at vulncheck.com> wrote:
> Hey Esteban,
> We have provisionally reserved the following CVE for this vulnerability:
> *CVE-2026-102639*.
> Credit is awarded to *Harsh Raj Singhania* as the finder.
> Additionally, I've attached the proposed CVE Record to this email, please
> review it and let us know if anything needs to be changed.
> Thank you,
> On Tue, Sep 29, 2026 at 11:37 AM Esteban Zimanyi <estebanzimanyi at gmail.com>
> wrote:
>> Hello,
>> Thank you for the report and for coordinating the disclosure.
>> We have reproduced the issue and confirmed the root cause described in
>> the report. The Well-Known Binary (WKB) bounds check in
>> meos/src/temporal/type_in.c added the requested length to the parse
>> position, so a negative or very large length read from the input, such as
>> the length of a text value, wrapped the pointer and passed the check. The
>> only other guard was an assertion, which release builds compile out. With
>> the reporter's payload, AddressSanitizer reports negative-size-param
>> (size=-1) in text_from_wkb_state.
>> The fix compares every read with the bytes remaining in the buffer,
>> rejects a negative or oversized length or count before it is used, checks
>> that the type code in the header names a type of the expected family, and
>> stops parsing at the first failed check, including when MEOS is used as a
>> library with an error handler that returns. We validated it with the
>> PostgreSQL regression suite and with sanitizer-instrumented fuzzing of the
>> binary input functions (several million malformed inputs per branch, with
>> no memory error in the WKB readers).
>> Affected versions: MobilityDB 1.1.x, 1.2.0, 1.2.1 and 1.3.0, and the
>> development branch. We are publishing the fix today on the development
>> branch and in patch releases of the 1.3 and 1.2 series, together with a
>> GitHub security advisory. Please go ahead with the CVE record; could you
>> send us the CVE ID so that we can add it to the advisory and the release
>> notes? Please also let us know how the researcher would like to be credited.
>> Best regards,
>> Esteban
>> fax: + 32.2.650.47.13 <+32%202%20650%2047%2013>
>> tel: + 32.2.650.31.85 <+32%202%20650%2031%2085>
>> On Mon, Sep 28, 2026 at 3:48 PM Brandon Tarr via Mobilitydb-dev <
>> mobilitydb-dev at lists.osgeo.org> wrote:
>>> Greetings MobilityDB Security Team,
>>> I'm a vulnerability analyst at VulnCheck <https://www.vulncheck.com/>
>>> an exploit intelligence company and research CVE Numbering Authority (CNA),
>>> where I'm one of several folks who manage our coordinated vulnerability
>>> disclosure (CVD) program.
>>> An external security researcher recently reported
>>> <https://www.vulncheck.com/advisories/report> a potential vulnerability
>>> impacting [MobilityDB / MobilityDB
>>> <https://github.com/MobilityDB/MobilityDB>] and VulnCheck is acting as
>>> the intermediary and coordinator.
>>> VulnCheck follows a 120-day disclosure policy
>>> <https://www.vulncheck.com/vulnerability-disclosure-policy>, meaning we
>>> afford vendors/maintainers up to 120 days from the time of receiving the
>>> report to address the issue before publication of a CVE record and
>>> third-party advisory. For this vulnerability, the 120-day deadline is *January
>>> 26, 2027 (26/01/2027)*. Of note, patch publication constitutes public
>>> disclosure — if a patch is issued, we will publish the CVE record at that
>>> time rather than waiting for the full 120-day window.
>>> The researcher has provided us with a comprehensive technical report,
>>> which we have attached to this email. Let us know if you have any questions
>>> for us about the CVD process or for the researcher regarding the reported
>>> vulnerability.
>>> Thank you,
>>> Brandon Tarr
>>> VulnCheck
>>> Mobilitydb-dev mailing list
>>> Mobilitydb-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mobilitydb-dev
> Thank you,
> Brandon Tarr
> VulnCheck
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20260929/56f86308/attachment.htm>
More information about the Mobilitydb-dev
