[Mobilitydb-users] Query regarding intersection of a temporal point with Z dimension and polygon
Esteban Zimanyi estebanzimanyi at gmail.com
Thu Mar 11 08:25:40 PST 2021
Dear Sharath
I analyzed the query you sent me and I need a little more information about
what do you want to obtain.
According to my understanding you needed to project the trips with respect
to a bounding box AND a time period. If this is the case, you case use a
query as the following one
with temp(box) as (
  select stbox(geometry 'SRID=3857;POLYGON((485292.553920999
6593648.95191558, 485292.553920999 6597648.95191558,
    489292.553920999 6597648.95191558, 489292.553920999 6593648.95191558,
485292.553920999 6593648.95191558))',
    period '[2020-06-01 08:00, 2020-06-02 12:00]') )
select atStbox(trip, box) from trips, temp;
Is that what you want?
Regards
Esteban
Prof. Esteban Zimanyi
Department of Computer & Decision Engineering  (CoDE) CP 165/15
Universite Libre de Bruxelles
Avenue F. D. Roosevelt 50
B-1050 Brussels, Belgium
fax: + 32.2.650.47.13
tel: + 32.2.650.31.85
e-mail: ezimanyi at ulb.ac.be
Internet: http://cs.ulb.ac.be/members/esteban/
On Mon, Mar 8, 2021 at 8:13 AM Sharath S Bhargav <shrthsbhargav96 at gmail.com>
wrote:
> Hello,
> I want to store the trajectory of an object with all 3 dimensions and find
> the intersection with a polygon with z dimension defined as well. I am able
> to get a result of "true" when I use the function "intersects" but I get a
> false value when I use "tintersects". Could someone let me know how
> MobilityDB operates on the Z dimension of a point.
> Any help on how to proceed with 3 dimensions in MobilityDB would be
> much appreciated.
> Thank you,
> Sharath
> Mobilitydb-users mailing list
> Mobilitydb-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mobilitydb-users
URL: <http://lists.osgeo.org/pipermail/mobilitydb-users/attachments/20210311/b5c0f70a/attachment.html>
More information about the Mobilitydb-users mailing list
