[Mobilitydb-users] MobiltyDB for Windows
Esteban Zimanyi estebanzimanyi at gmail.com
Wed Sep 1 06:30:29 PDT 2021
I see already a problem, since your SRID is 4326, and therefore there is no
possibility to use distance functions such as dwithin in this SRID since
the units of the system are in degrees. You need to use a projection and
the result of the dwithin function on it would return values in the unit of
measure of the SRID.
Prof. Esteban Zimanyi
Department of Computer & Decision Engineering  (CoDE) CP 165/15
Universite Libre de Bruxelles
Avenue F. D. Roosevelt 50
B-1050 Brussels, Belgium
fax: + 32.2.650.47.13
tel: + 32.2.650.31.85
e-mail: esteban.zimanyi at ulb.be
Internet: http://cs.ulb.ac.be/members/esteban/
On Wed, Sep 1, 2021 at 3:04 PM <suc.eleve at ecole-navale.fr> wrote:
> I use mobiltyBD for docker, version 1.0 beta3. The SRID is WGS84
> (4326). I will find attached, a csv and a backup of a table I created
> with only three ships, the one of the screen shot is one of them, one
> other come close to this one (212m), and other one stays far away (59km)
> Best Regards,
> A. Suc
URL: <http://lists.osgeo.org/pipermail/mobilitydb-users/attachments/20210901/a7306f7d/attachment.html>
More information about the Mobilitydb-users mailing list
