[Mobilitydb-users] transform() and LCC
Wendell Turner
WTurner at cssiinc.com
Wed May 29 06:44:33 PDT 2024
Hello,
I'm having trouble using transform() to convert to Lambert Conformal Conic. The response is:
ERROR: Transform: Could not form projection from 'srid=4326' to 'srid=102004' (SQLSTATE XX000)"
The PostGIS installation populates the spatial_ref_sys table with many projections, including LCC:
# select auth_name, auth_srid from spatial_ref_sys where srid=102004;
auth_name | auth_srid
ESRI | 102004
I see in meos/src/point/type_srid.c there is:
len = snprintf(srid_to_str, MAX_EPSG_STR, "EPSG:%d", srid_to);
Does this mean that there an issue with non-EPSG projection codes?
Thank you,
Wendell
URL: <http://lists.osgeo.org/pipermail/mobilitydb-users/attachments/20240529/a780f164/attachment.htm>
More information about the Mobilitydb-users
