[Mobilitydb-users] get a geom of a part of a trajectory
Jan Willem van der Lichte
jwgvanderlichte at gmail.com
Wed Oct 9 04:47:14 PDT 2024
Hi List
I have a question about splitting a trajectory into 2 parts by a "blade"
linestring, and store both parts of that trajectory as a geometry in
seperate fields (left_geometry and right_geometry)
First of all I made a table with all trajectories
CREATE TABLE rr_trips_totaal(rr_id, rr_datum, rr_bestand, rr_trip, rr_traj)
as
SELECT ritid as rr_id,
datum as rr_datum,
bestand as rr_bestand,
tgeompoint_seq(array_agg(tgeompoint_inst( ST_Transform(geometry, 3857),
date) ORDER BY date)),
trajectory(tgeompoint_seq(array_agg(tgeompoint_inst(
ST_Transform(geometry, 3857), date) ORDER BY date)))::geometry
FROM ruwe_rit_data
GROUP BY ritid, datum, bestand;
CREATE INDEX rr_trips_totaal _idx ON rr_trips_totaal USING GiST(rr_trip);
First of all I try to find the direction of the trip going through my
blade
Therefor I created the table "splitsing" with two records containing
linegeometries called "lijn1" and "lijn2"
As far as I understand the atGeometry() returns a (point)geometry
the direction is created int het case in the query below
I'm not sure if this is the right way to do this (should I use time?)
SELECT row_number() over () as id,
a.rr_id,
a.rr_datum,
a.rr_bestand,
a.rr_traj,
case
when atGeometry(a.rr_trip, b.geom) < atGeometry(a.rr_trip, c.geom) then
'richting1'
when atGeometry(a.rr_trip, b.geom) > atGeometry(a.rr_trip, c.geom) then
'richting2'
end case
from rr_trips_totaal a,
(select * from splitsing where naam='lijn1' and locatie='bij kattenrug') as
b,
(select * from splitsing where naam='lijn2' and locatie='bij kattenrug') as
c
at this point I have a data set of rr_trips_totaal including the field
"case" in which the direction is stored.
Now I want to cut the trip into two parts to the geometry fields
"trip_before_split" and "trip_after_split" and here i'm getting confused.
I tried something with the st_dump(st_split()), but in some case there
were a lot more than 2 path part, so that didn't work
(st_dump(st_split(a.rr_traj, b.geom))).path[1] As path,
(st_dump(st_split(a.rr_traj, b.geom))).geom As deelgeom
Is it possible to get the geometry from startpoint to 'cut-point' (or
start-time- to 'cut-time') and from 'cut-point/time' to end-point/time.
Or does anyone know an example of such a query?
Have I overlooked a function te get a part of a trajectory?
Any help would be nice
Met groet,
Jan Willem
URL: <http://lists.osgeo.org/pipermail/mobilitydb-users/attachments/20241009/b274dd17/attachment.htm>
More information about the Mobilitydb-users
