[Mobilitydb-users] Joint release candidate of MobilityDB and MEOS 1.2.0
SCHOEMANS Maxime maxime.schoemans at ulb.be
Thu Sep 26 08:03:32 PDT 2024
MobilityDB 1.2.0rc1
The MobilityDB team is proud to announce the first release candidate of MobilityDB and MEOS 1.2
https://github.com/MobilityDB/MobilityDB/releases/tag/v1.2.0rc1
MobilityDB 1.2 supports PostgreSQL versions 13-17.
Major changes w.r.t. MobilityDB 1.1
* Add support for PG 17 and remove support for PG 12
* Update embedded PostGIS code from 3.2 to 3.5
* QoL changes to the build and test processes
* Multiple bug fixes
* Performance improvements
* SQL and C API changes
* Fix memory leaks in MEOS
* Add support for pkg-config to the MEOS shared library
Full Changelog:
https://github.com/MobilityDB/MobilityDB/compare/v1.1.1...v1.2.0rc1
MobilityDB 1.1.2
We are also proud to announce the release of MobilityDB and MEOS 1.1.2
https://github.com/MobilityDB/MobilityDB/releases/tag/v1.1.2
This release adds support for PostgreSQL 17 to MobilityDB 1.1
Full Changelog:
https://github.com/MobilityDB/MobilityDB/compare/v1.1.1...v1.1.2
Best regards,
The MobilityDB Team
URL: <http://lists.osgeo.org/pipermail/mobilitydb-users/attachments/20240926/50ca9dbb/attachment.htm>
More information about the Mobilitydb-users mailing list
