[Oceania-Board] motions: let F4G Oceania 2020 access all Good Mojo funds
Adam Steer
adam.d.steer at gmail.com
Mon Oct 5 01:19:22 PDT 2020
...wrapping this thread up - two motions were proposed:
- make all Good Mojo funds available to FOSS4G SotM Oceania 2020
inclusivity initiatives
- delegate funding allocation for projects aligned with the Good Mojo
initiative to the LOC and hub managers, ie let the locals decide what is
valuable work for raising under-heard voices in the community.
There are not enough responses to either to make a decision. For the first,
two positive responses were received. For the second, two negative
These were both aimed at getting money donated by the community spent in
the community without the board needing to scrutinise every decision, and
with some urgency given an approaching conference, I'm not sure why this
issue isn't seen as important.
If someone has a better solution please propose it!
Thanks,
Adam
URL: <http://lists.osgeo.org/pipermail/oceania-board/attachments/20201005/47d99282/attachment.html>
More information about the Oceania-Board
