[Oceania-Board] 2024-2025 budget
Ewen Hill
ewen.hill at gmail.com
Thu Jun 6 18:12:52 PDT 2024
Hi all,
Thanks for all the hard work on this. I think it could be worthwhile
using a conventional ledge of income vs expenses and to break out items
into separate sheets like administrative expenses and conferences. Seeing
an amount of $90k income should be able to be drilled down a little - say
to amounts over $3-$5k? It would mean that those not involved on the
finance side can see how our reserves are spent and the significant risk
(and rewards) of the global conference.
Regards
Ewen
On Thu, 6 Jun 2024 at 12:44, John Bryant via Oceania-Board <
oceania-board at lists.osgeo.org> wrote:
> Yes, I think we should talk through column H as a group, perhaps make some
> adjustments as we go, then hopefully we'll have something we can approve.
> Cheers
> John
> On Thu, 6 Jun 2024 at 09:46, Alex Leith <alexgleith at gmail.com> wrote:
>> Hi John
>> Thanks for putting this together. I think it's comprehensive and
>> reasonably accurate.
>> If the Hobart event goes well, I hope we can replicate Melbourne and
>> Wellington and achieve a $60 k surplus, but let's not bank on that.
>> The forecast budget for next year with a $30 k surplus from Hobart is a
>> $20 k loss, but that includes provision of a $23 k advance to the Auckland
>> conference, which isn't necessarily going to be required. It's hard to
>> budget for something that is so far out... but also, keep in mind, we'll
>> likely start getting sponsors for the Auckland conference next FY too, so
>> there'll hopefully be income as well as expenses for that event.
>> Also, for context, as of Today, we have $57,000 in the bank. This is down
>> from a peak of around $80 k, so it's about time we started having some good
>> years that add to this!
>> Are we ready to table a budget at the Board meeting for approval tomorrow?
>> Cheers,
>> On Tue, 4 Jun 2024 at 11:27, John Bryant via Oceania-Board <
>>> Thanks, I've updated the sheet to reflect this.
>>> All - I've added a column H to the sheet
>>> <https://docs.google.com/spreadsheets/d/1gRWZXt1bZqTqNMf5sr7Ff5dH4Sp_Nabe4QoZHPPPpmw/edit#gid=1487652216>,
>>> we can use this to work out our final budget numbers for approval. I've
>>> left 3 scenarios in there for discussion, but I think we need to settle on
>>> one set of numbers (and review later if needed).
>>> If there's any more discussion in the next few days, that's great,
>>> otherwise we can discuss (and finalise) at Friday's meeting.
>>> Cheers
>>> John
>>> On Mon, 3 Jun 2024 at 11:06, Alex Leith <alexgleith at gmail.com> wrote:
>>>> Hi John
>>>> Yes, $30 k should be guaranteed as a minimum.
>>>> That's a good point about the global event... it's going to be hard to
>>>> budget. Maybe we should be budgeting the $25 k seed funding as an expense
>>>> and no income from the event, actually. Or we do the budget without
>>>> Auckland, and update if it's successful (though we should hear any day now!)
>>>> Cheers,
>>>> On Mon, 3 Jun 2024 at 12:55, John Bryant <johnwbryant at gmail.com> wrote:
>>>>> Thanks Alex, that sounds good, should we use $30k as the projected
>>>>> surplus in our budget?
>>>>> Yes that makes sense re: FOSS4G 2025 (though I thought maybe the PCO
>>>>> was handling all the funds until acquittal). If we get the green light, I
>>>>> suppose we should estimate how much $ we will handle in FY 2024-25.
>>>>> Cheers
>>>>> John
>>>>> On Mon, 3 Jun 2024 at 10:41, Alex Leith <alexgleith at gmail.com> wrote:
>>>>>> Hi John
>>>>>> Regarding Hobart, we have a handful of registrations and one
>>>>>> sponsorship already, and we have over a dozen submissions to talk, with
>>>>>> over a month to go. I've reviewed the budget and started capturing actuals,
>>>>>> and everything is still aligned to the approved budget in terms of
>>>>>> expenses. In short, I'm optimistic we'll achieve a surplus of at least $30
>>>>>> k.
>>>>>> Also, keep in mind that if we do hold the 2025 global event in
>>>>>> Auckland, we'll likely start receiving revenue next FY.
>>>>>> Cheers,
>>>>>> On Mon, 3 Jun 2024 at 12:27, John Bryant via Oceania-Board <
>>>>>>> Hi all, we need to sort out our budget ASAP so that we can have
>>>>>>> clarity on spending for the next financial year (which begins on 1 July).
>>>>>>> We've said a few times we need to give clarity on TGP in particular. I
>>>>>>> think we should try to wrap it up at our board meeting this Friday, if
>>>>>>> possible.
>>>>>>> I've updated this draft budget sheet
>>>>>>> <https://docs.google.com/spreadsheets/d/1gRWZXt1bZqTqNMf5sr7Ff5dH4Sp_Nabe4QoZHPPPpmw/edit#gid=1487652216> with
>>>>>>> as much current info & projections as I can. *I've currently got 3
>>>>>>> scenarios but I think our budget should settle on one*, and perhaps
>>>>>>> do a budget review once we get a better idea of Hobart revenue.
>>>>>>> A few notes/questions:
>>>>>>> - Current FOSS4G SotM Oceania 2024 amounts are based on the
>>>>>>> approved conf budget, minus GST and amounts paid/received in FY 2023-24. @Alex
>>>>>>> Leith <alexgleith at gmail.com> are there any updates to these
>>>>>>> projected amounts? Do we have a sense yet of which scenario is most likely,
>>>>>>> or is it too early to say? I think this is our biggest variable.
>>>>>>> - Community investments: we need to decide on our approach. Do
>>>>>>> we take a conservative approach and increase this amount as we gain
>>>>>>> confidence in a Hobart surplus, or do we "go big" and hope for the best?
>>>>>>> - Our operational expenses are relatively fixed, but we could
>>>>>>> find ways to save here, if we put some effort in.
>>>>>>> - We could get a bit more interest income by using a term
>>>>>>> deposit, if we know how much we can lock away and for how long.
>>>>>>> Also, a fairly big one... there's still the question of FOSS4G
>>>>>>> 2025 Auckland, and what impact that would have on our budget. Right now
>>>>>>> it's in there as an expense, with no revenue, I'm not sure if this is
>>>>>>> right. We should be finding out any day now whether this is happening, so
>>>>>>> maybe we stand by until we know?
>>>>>>> The bottom line is distinctly in the red but the FOSS4G 2025 amount
>>>>>>> is effectively a loan that will be repaid in future, without this amount
>>>>>>> we're at a surplus (assuming Hobart projections are reasonable).
>>>>>>> Thoughts?
>>>>>>> Cheers
>>>>>>> John
>>>>>>> On Sat, 4 May 2024 at 17:53, Dorothy D.Pion <ddpion at mra.gov.pg>
>>>>>>> wrote:
>>>>>>>> Hi Alex,
>>>>>>>> Sorry for the delay in getting back to you all.
>>>>>>>> It's unfortunate that we won't be receiving funding from TGP this
>>>>>>>> year. We'll need to cover expenses ourselves for now. Considering this, we
>>>>>>>> may need to reassess our budget and possibly reduce the number of TGP
>>>>>>>> grants we can offer this year?
>>>>>>>> Eli, Let me know your thoughts on this.
>>>>>>>> Best regards,
>>>>>>>> Dorothy
>>>>>>>> *Dorothy D.Pion*Senior Cartographer
>>>>>>>> Mineral Resources Authority | PO Box 1906, Port Moresby 121, Papua
>>>>>>>> New Guinea | *P: *(675) 2072250 |* F: * | *E: *ddpion at mra.gov.pg
>>>>>>>> | *W: *www.mra.gov.pg
>>>>>>>> [image: e banner_v3.JPG] [image: GEE24 Banner 4.jpg]
>>>>>>>> DISCLAIMER: This message contains privileged and confidential
>>>>>>>> information intended only for the addressee(s). If you are not the intended
>>>>>>>> recipient of this message, you must not disseminate, copy and/or take any
>>>>>>>> action in reliance on it. If you have received it in error, please notify
>>>>>>>> the sender by return email and delete it completely. Nothing contained in
>>>>>>>> this email is intended to be an offer to commit MRA to any purchase, sale,
>>>>>>>> contract, or any other dealing. It is also important to check for viruses
>>>>>>>> and defects before opening or using any attachments. MRA will not be liable
>>>>>>>> for any course of action and its liability shall be limited to re-supplying
>>>>>>>> any affected attachments only.
>>>>>>>> *From:* Oceania-Board <oceania-board-bounces at lists.osgeo.org> on
>>>>>>>> behalf of Alex Leith via Oceania-Board <
>>>>>>>> *Sent:* Saturday, May 4, 2024 9:01 AM
>>>>>>>> *To:* John Bryant <johnwbryant at gmail.com>
>>>>>>>> *Cc:* OSGeo Oceania Board <oceania-board at lists.osgeo.org>
>>>>>>>> *Subject:* Re: [Oceania-Board] 2024-2025 budget
>>>>>>>> HEre's what Angelos said:
>>>>>>>> Unfortunately the TGP budget is out for this year :(
>>>>>>>> The financial year starts Jan 1st.
>>>>>>>> Amending the budget is a possibility if we get funding during the
>>>>>>>> year.
>>>>>>>> So, I guess we won't get cash from them this time, unfortunately.
>>>>>>>> On Thu, 2 May 2024 at 13:04, Alex Leith <alexgleith at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Yeah, ok. I guess we'll need to cover it ourselves then... will
>>>>>>>> need to re-assess.
>>>>>>>> I'll let you all know if I hear anything different from Angelos.
>>>>>>>> On Thu, 2 May 2024 at 08:01, John Bryant <johnwbryant at gmail.com>
>>>>>>>> wrote:
>>>>>>>> I'm not 100% sure but I think it's Apr-Mar.
>>>>>>>> This was approved in February
>>>>>>>> <https://wiki.osgeo.org/wiki/Board_Meeting_2024-02-06#OSGeo_Budget_2024> (amounts
>>>>>>>> in USD):
>>>>>>>> - Travel Grant Program: 10k $ to be approved. The direction is
>>>>>>>> to use 7k for global FOSS4G and 3k for local events.
>>>>>>>> So our request was for their entire local event TGP budget,
>>>>>>>> probably we're asking for far too much.
>>>>>>>> Cheers
>>>>>>>> John
>>>>>>>> On Thu, 2 May 2024 at 05:54, Alex Leith <alexgleith at gmail.com>
>>>>>>>> wrote:
>>>>>>>> What is their financial year?
>>>>>>>> I'll ask Angelos if we can request again for the next FY.
>>>>>>>> On Thu, 2 May 2024 at 07:18, eli via Oceania-Board <
>>>>>>>> oh that's not nice. I suppose the lesson is learned, we need to
>>>>>>>> apply for the TGP as soon as OSGeo plan their budget next time.
>>>>>>>> Il giorno gio 2 mag 2024 alle ore 09:15 John Bryant via
>>>>>>>> Oceania-Board <oceania-board at lists.osgeo.org> ha scritto:
>>>>>>>> Hi all, FYI:
>>>>>>>> Unfortunately our request for TGP funding from OSGeo was not
>>>>>>>> approved, see meeting minutes
>>>>>>>> <https://wiki.osgeo.org/wiki/Board_Meeting_2024-04-30#FOSS4G_SotM_Oceania_TGP_Request>.
>>>>>>>> The OSGeo TGP budget has already been spent for this year.
>>>>>>>> John
>>>>>>>> On Wed, 24 Apr 2024 at 10:16, John Bryant <johnwbryant at gmail.com>
>>>>>>>> wrote:
>>>>>>>> I think it's a good idea to model a pessimistic scenario, but the
>>>>>>>> $4k surplus isn't that pessimistic - it's based on a conference surplus
>>>>>>>> that's more than double Auckland's surplus.
>>>>>>>> A moderately pessimistic scenario would have to contain the
>>>>>>>> possibility the 2024 conference surplus is similar to 2023, ie ~13k. I'm
>>>>>>>> optimistic too, but given that Auckland is a much bigger market than
>>>>>>>> Hobart, and cost of living pressures are making people very cautious about
>>>>>>>> discretionary spending, I think we have to consider it within the realm of
>>>>>>>> possibility.
>>>>>>>> I've done a moderately pessimistic "scenario 2" in the simplified
>>>>>>>> sheet that includes this contingency. It puts the TGP at $15k, reduces
>>>>>>>> other community investment (grants, sponsorship, WGs) by $5k, and it puts
>>>>>>>> us at a loss of ~$12k. Hopefully very unlikely, but at this stage we just
>>>>>>>> don't know - our most recent experience indicates that it's possible.
>>>>>>>> I don't think we're in a financial position right now to allocate
>>>>>>>> more than we've ever spent on TGP, at a point when we're at maximum
>>>>>>>> uncertainty about conference income. Our past experience has shown us we
>>>>>>>> can approach it progressively - allocate a modest amount now, and increase
>>>>>>>> it when we become more confident we have the surplus to support it.
>>>>>>>> I guess what I'm saying is that I think we should start small, and
>>>>>>>> grow it when we hit sponsorship and registration targets, otherwise we run
>>>>>>>> the risk we 1) make a large loss again next year and/or 2) have to cut
>>>>>>>> other community investments.
>>>>>>>> Cheers
>>>>>>>> John
>>>>>>>> On Wed, 24 Apr 2024 at 07:24, Alex Leith <alexgleith at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Hi John
>>>>>>>> I think targeting a $4 k surplus is ok in the pessimistic scenario.
>>>>>>>> I really hope that we can deliver something like a $60 k surplus
>>>>>>>> from the conference, like we did in Melbourne and Wellington. I'm always
>>>>>>>> fairly optimistic, but I have had a lot of people say that they're excited
>>>>>>>> to come to Hobart, and we can handle a pretty big crowd... so maybe we'll
>>>>>>>> exceed expectations.
>>>>>>>> I'm ok with starting the budget with a modest TGP allocation of $15
>>>>>>>> k including the OSGeo cash and increasing if we can.
>>>>>>>> Cheers,
>>>>>>>> On Tue, 23 Apr 2024 at 19:32, John Bryant <johnwbryant at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Thanks Elisa, that's really helpful input. I had a rough idea of
>>>>>>>> what had happened, but I didn't know we hadn't actually planned to do PGRSC
>>>>>>>> as part of the program. So this year, should we proactively include other
>>>>>>>> events in our TGP budget?
>>>>>>>> Let me ask everyone... what if we zoom out for a moment, simplify,
>>>>>>>> and think of the budget as having 3 major components:
>>>>>>>> - *Conference surplus*: Virtually all of our income is derived
>>>>>>>> from this one source, and needs to pay for everything else, so this is
>>>>>>>> crucial; but it's handled in detail by another budget - we can provide
>>>>>>>> oversight using that budget.
>>>>>>>> - *Operational expenses*: These are relatively predictable and
>>>>>>>> fixed; we can fiddle with them a bit, but it looks like they'll be
>>>>>>>> somewhere in the range of $6000-10000.
>>>>>>>> - *Community Investment expenses*: This is where we have the
>>>>>>>> most discretion. For the current financial year we're on target to spend
>>>>>>>> around $20k.
>>>>>>>> *So.... what if we figure out the total amount we can afford to
>>>>>>>> spend in the Community Investment category, and then allocate that into
>>>>>>>> TGP, Grants, Sponsorship, and Committees/WGs?* The benefit of this
>>>>>>>> approach is 1) we spend what we can afford and 2) we consider the relative
>>>>>>>> impact where we invest. We have a finite amount of money - if we spend $10k
>>>>>>>> on X, we can't spend it on Y or Z, even if Y or Z might actually have a
>>>>>>>> bigger impact.
>>>>>>>> It forces us to contend with the question: If our total community
>>>>>>>> investment spend is $25k, and we spend $15k on the TGP, do we cut back on
>>>>>>>> other grants and sponsorship?
>>>>>>>> I've added a "simple" version to this tab of the budget sheet
>>>>>>>> to make it a little easier to reason with, and I've adjusted a couple of
>>>>>>>> numbers based on Alex's suggestions. Even with ops costs cut right back,
>>>>>>>> and "only" 10k allocated to TGP, it leaves us with a relatively modest
>>>>>>>> surplus of $4300. Increase the TGP to 15k and we're in the red - would need
>>>>>>>> to cut it from somewhere else (or ensure we have a bigger conference
>>>>>>>> surplus).
>>>>>>>> John
>>>>>>>> On Tue, 23 Apr 2024 at 15:47, eli <elipuccioni at gmail.com> wrote:
>>>>>>>> Actually I have an input re:TGP:
>>>>>>>> The higher budget we had for Auckland and (hopefully) we will have
>>>>>>>> for Hobart is aiming to enable more participation from the pacific. We have
>>>>>>>> noticed that smaller grants cut the majority of the pacific applicants off,
>>>>>>>> due to the cost of traveling. So I’m in full support of this higher
>>>>>>>> spending on TGP (no surprises here!).
>>>>>>>> Moreover, because of the problems with NZ immigration last year, we
>>>>>>>> “moved” people from Auckland to Suva, so PGRSC grantees were actually
>>>>>>>> FOSS4G winners, we didn’t have a separate budget and program for that
>>>>>>>> conference. That said, one of my personal goals would be extending the TGP
>>>>>>>> to relevant conferences in the Pacific, especially the PGRSC, but I
>>>>>>>> understand that might not be possible to implement every year and will
>>>>>>>> depend on our finances.
>>>>>>>> Cheers,
>>>>>>>> Elisa
>>>>>>>> Potrebbe andar peggio...potrebbe piovere!
>>>>>>>> Il giorno mar 23 apr 2024 alle 19:36 eli <elipuccioni at gmail.com>
>>>>>>>> ha scritto:
>>>>>>>> Thanks both Alex and John for this and support of I’m not adding
>>>>>>>> much input in this. As Jonah said, I am too learning from your expertise
>>>>>>>> and feel I still have a bit of learning to do before contributing more
>>>>>>>> actively!
>>>>>>>> Cheers,
>>>>>>>> Elisa
>>>>>>>> Il giorno mar 23 apr 2024 alle 18:40 John Bryant via Oceania-Board <
>>>>>>>> Thanks Alex, I've made a few modifications to the sheet based on
>>>>>>>> your suggestions:
>>>>>>>> - split event income & expenses (I used the Hobart budget
>>>>>>>> middle scenario for these amounts, ex GST)
>>>>>>>> - split the single conference line into separate lines for each
>>>>>>>> event
>>>>>>>> - put OSGeo TGP grant into 2024 projected rather than 2025
>>>>>>>> budgeted
>>>>>>>> Having the conference items separated out like that is a bit more
>>>>>>>> complex, but I like the extra detail. The big thing that jumps out at me,
>>>>>>>> though, is the need to refine the conference estimates as early as we can.
>>>>>>>> Re: TGP, I'm certainly open to the suggestion of increasing it (if
>>>>>>>> we have good reason), I think it's an important part of what we do.
>>>>>>>> It would be great to have more insight into how much money we
>>>>>>>> actually need, and what we're aiming for. By my calculations, this is what
>>>>>>>> we've spent over the years:
>>>>>>>> - Melbourne 2018: $4650 for 7 people
>>>>>>>> - Wellington 2019: $9000 for 14 people
>>>>>>>> - Auckland 2023: $6400 for 5 people
>>>>>>>> - PGRSC 2023: $5100 for 3 people
>>>>>>>> Would the Hobart TGP be significantly different from Auckland?
>>>>>>>> Should we include other events this year (eg PGRSC) in our budget?
>>>>>>>> One other thought - in 2018 and 2019, we started off with a modest
>>>>>>>> budget for the TGP and increased it as we became more confident we had the
>>>>>>>> funds. Could this approach work for us this year as well?
>>>>>>>> By the way, everyone, Alex and I are engaging in this, but he's
>>>>>>>> right, all board members should be thinking about our finances and
>>>>>>>> providing their input (please).
>>>>>>>> Cheers
>>>>>>>> John
>>>>>>>> On Mon, 22 Apr 2024 at 18:32, Alex Leith <alexgleith at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Ok, so here's the notes from the march minutes
>>>>>>>> <https://docs.google.com/document/d/1LMz-7ENIqbuE-QGhqB6ryO9bDRYFS0E4bxZMgjJQb2w/edit>:
>>>>>>>> - Intent to allocate 10k to TGP (pending FY24/25 budget
>>>>>>>> discussion and approval)
>>>>>>>> - Planning to request USD5k from OSGeo (Dorothy will write it
>>>>>>>> up)
>>>>>>>> It's a little ambiguous, but I'd like to request that we allocate
>>>>>>>> $10 k from the OO budget plus the $5 k (AUD) from OSGeo.
>>>>>>>> We've kicked off the TGP early, and I'm hoping we can spend our
>>>>>>>> allocation and bring as many people as we can along to the event in Hobart,
>>>>>>>> so if we're as successful as we have been in past years, I'd love to
>>>>>>>> increase the amount that's available too.
>>>>>>>> If we have a starting point of $15 k, that will set Dorothy up
>>>>>>>> nicely to start planning.
>>>>>>>> On Mon, 22 Apr 2024 at 19:44, John Bryant <johnwbryant at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Thinking a bit more about TGP...
>>>>>>>> I suggest this:
>>>>>>>> - we allocate $10k to TGP (including OSGeo $5000)
>>>>>>>> - if the OSGeo request is declined, we reconsider our allocation
>>>>>>>> - if/when conference sponsors provide extra TGP funds, we
>>>>>>>> increase the amount accordingly
>>>>>>>> In total, this would be roughly in line with how much we spent last
>>>>>>>> year, and should be enough for the 10 TGP registrations allocated in the
>>>>>>>> conference budget, potentially with money left over for other events.
>>>>>>>> Cheers
>>>>>>>> John
>>>>>>>> On Mon, 22 Apr 2024 at 15:28, John Bryant <johnwbryant at gmail.com>
>>>>>>>> wrote:
>>>>>>>> I wasn't at the March meeting, but it sounded like the outcome was
>>>>>>>> that the discussion would happen later when we talked about the budget. I
>>>>>>>> don't think we've had any other discussions about it?
>>>>>>>> So I reckon this is the budget discussion where we should make that
>>>>>>>> decision.
>>>>>>>> These seem like relevant points:
>>>>>>>> - the Hobart conf budget accounts for 10 TGP regos
>>>>>>>> - this year we spent ~12k including the OSGeo $5k
>>>>>>>> I haven't seen an accounting of last year's TGP (number and amount
>>>>>>>> of grants) but it would be useful, if anyone knows about it?
>>>>>>>> Cheers
>>>>>>>> John
>>>>>>>> On Mon, 22 Apr 2024 at 15:12, Alex Leith <alexgleith at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Oh, I thought we agreed on $20 k like last year?
>>>>>>>> Apologies if I remembered wrong.
>>>>>>>> Was the $10 k you thought we agreed including the OSGeo money?
>>>>>>>> *Alex Leith*
>>>>>>>> m: +61 419 189 050
>>>>>>>> https://auspatious.com
>>>>>>>> On Mon, 22 Apr 2024 at 5:11 PM, John Bryant <johnwbryant at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Thanks everyone, great comments so far.
>>>>>>>> Alex, one question, you said "We have earmarked $20 k for the TGP
>>>>>>>> for the Hobart conference"... all I'm aware of is a discussion at the March
>>>>>>>> board meeting where the outcome was: "Intent to allocate 10k to TGP
>>>>>>>> (pending FY24/25 budget discussion and approval)"
>>>>>>>> Where does the $20k figure come from?
>>>>>>>> Cheers
>>>>>>>> John
>>>>>>>> On Mon, 22 Apr 2024 at 09:04, Jonah Sullivan <
>>>>>>>> jonahsullivan79 at gmail.com> wrote:
>>>>>>>> I'm really glad to see Alex and John engaging on the very important
>>>>>>>> topic of financial probity. I probably shouldn't have raised my hand as
>>>>>>>> treasurer, considering my lack of experience and annoying work commitments,
>>>>>>>> but I'm glad to be more involved in the process - I'm learning a lot
>>>>>>>> already.
>>>>>>>> On Mon, 22 Apr 2024, 08:53 Alex Leith via Oceania-Board, <
>>>>>>>> Hi John
>>>>>>>> For this FY, here's some comments:
>>>>>>>> - I requested travel grant funding from OSGeo a week ago for
>>>>>>>> $3,500 USD. That should be received this FY, I expect.
>>>>>>>> - The other hard to forecast difference is sponsorship and
>>>>>>>> ticket sales for the conference, which should start happening this FY. I'm
>>>>>>>> hoping to start reaching out to potential sponsors, and some organisations
>>>>>>>> like spending money in the current FY. I expect to have some money flowing
>>>>>>>> in soon.
>>>>>>>> - I want to note that since our term deposits matured in
>>>>>>>> December, and we received ~$1,800, we haven't now got any cash earning
>>>>>>>> interest. I think it would be a good idea to put money away in a 12 month
>>>>>>>> term deposit, as we can now achieve 4.75% interest, so on $50 k, that's
>>>>>>>> over $2,000 of free money!
>>>>>>>> - We perhaps need a budget line for conference 2024, since we
>>>>>>>> have paid the deposit for the venue at $14 k.
>>>>>>>> For the 2025 budget:
>>>>>>>> - The $25 k surplus is quite conservative. I think we'll do
>>>>>>>> better than that for the conference, but it's nice to be conservative in
>>>>>>>> budgeting!
>>>>>>>> - We have earmarked $20 k for the TGP for the Hobart
>>>>>>>> conference. With $5 k coming from OSGeo, that leaves a worst case of $15 k
>>>>>>>> from OO. (This will be topped up by the conference with a portion of
>>>>>>>> sponsorship going to TGP.)
>>>>>>>> And just a note that we should be doing budgeting with the balance
>>>>>>>> sheet in mind too. We currently have $60 k in the bank, which is unusually
>>>>>>>> low, mostly because we have started paying expenses for the 2024
>>>>>>>> conference, but haven't got any income yet.
>>>>>>>> Now it's a fairly minor thing, but I would prefer to have a
>>>>>>>> separate line for conference income and conference expenses. We sometimes
>>>>>>>> have smaller regional events, and it's good to see the difference in
>>>>>>>> expense/income per event.
>>>>>>>> And one of those boring reminders too that as Board Directors, we
>>>>>>>> need to remember that we are all individually accountable for the financial
>>>>>>>> health of the organisation, we can't delegate that responsibility to
>>>>>>>> others, so please engage with this important work and make sure you
>>>>>>>> understand it!
>>>>>>>> Cheers,
>>>>>>>> Alex
>>>>>>>> [image: image.png]
>>>>>>>> Cheers,
>>>>>>>> On Sun, 21 Apr 2024 at 12:58, John Bryant via Oceania-Board <
>>>>>>>> Hi board,
>>>>>>>> The 2024-2025 financial year (FY25) begins on 1 July.
>>>>>>>> It would be good to move the FY25 budget forward, ideally we can
>>>>>>>> approve it in May but I'm sure there will be some discussion required.
>>>>>>>> Perhaps we can discuss in this thread over the next couple of weeks and put
>>>>>>>> it on the agenda for further discussion at the May board meeting?
>>>>>>>> My ambition with this is to:
>>>>>>>> - come up with a realistic set of numbers we can use to guide
>>>>>>>> spending decisions in the upcoming financial year
>>>>>>>> - set targets for income, community investment, and ultimately,
>>>>>>>> a surplus to help keep us solvent
>>>>>>>> - provide clear and visible financial targets and priorities to
>>>>>>>> the community
>>>>>>>> Can you please review the attached PDF and/or the Google Sheet
>>>>>>>> <https://docs.google.com/spreadsheets/d/1gRWZXt1bZqTqNMf5sr7Ff5dH4Sp_Nabe4QoZHPPPpmw/edit#gid=61568483>?
>>>>>>>> I've listed several questions that I hope will help us move it forward.
>>>>>>>> Your comments and questions please!
>>>>>>>> Thanks
>>>>>>>> John
>>>>>>>> On Fri, 29 Mar 2024 at 16:15, John Bryant <johnwbryant at gmail.com>
>>>>>>>> wrote:
>>>>>>>> Hi all,
>>>>>>>> We discussed at the February board meeting that we should get
>>>>>>>> moving on a budget for next year. I want to kick off a discussion towards
>>>>>>>> hopefully having a first draft within the next few weeks, and a final draft
>>>>>>>> for approval in May.
>>>>>>>> I have a sheet here
>>>>>>>> <https://docs.google.com/spreadsheets/d/1gRWZXt1bZqTqNMf5sr7Ff5dH4Sp_Nabe4QoZHPPPpmw/edit#gid=0> with
>>>>>>>> the current year projected and actual amounts for context.
>>>>>>>> For now, do you have any specific items on your wish list for next
>>>>>>>> year?
>>>>>>>> I have a few suggestions and questions:
>>>>>>>> - *Distinct "Operational" & "Community Investment" expense
>>>>>>>> categories*. By doing this, we make sure we allocate enough to
>>>>>>>> keep the lights on, and then we have better sight of what we can afford to
>>>>>>>> invest in community programs.
>>>>>>>> - *Separate grants and sponsorship*. They're accounted for
>>>>>>>> separately in Xero and I think it caused some confusion this year when we
>>>>>>>> overspent on the combined item. We ultimately increased the budget amount
>>>>>>>> but for a time the Grants committee was unsure if they should hit pause. By
>>>>>>>> separating these, I think we add clarity.
>>>>>>>> - *Remove "Special Interest Groups"?* We don't really have any
>>>>>>>> SIGs (OSM SIG has never been active, QGIS SIG wound up in June 2022). I
>>>>>>>> still think we should make these kinds of investments in OSM and QGIS
>>>>>>>> community groups of course, but maybe we do it under sponsorship and grants
>>>>>>>> line items?
>>>>>>>> - *TGP:* At the last board meeting there was talk of ~10k for
>>>>>>>> the Travel Grant Program, is this the right amount? It sounds like the
>>>>>>>> Hobart conference may have about $5000 to add to this, depending on
>>>>>>>> sponsorship (Alex correct me if I've got this wrong!).
>>>>>>>> Also I think we'll need to make a projection on the conference
>>>>>>>> surplus, perhaps this is an item for discussion at the next board meeting
>>>>>>>> on the 3rd.
>>>>>>>> Your thoughts?
>>>>>>>> Cheers
>>>>>>>> John
>>>>>>>> _______________________________________________
>>>>>>>> Oceania-Board mailing list
>>>>>>>> Oceania-Board at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/oceania-board
>>>>>>>> *Alex Leith*
>>>>>>>> m: +61 419 189 050
>>>>>>>> *Alex Leith*
>>>>>>>> m: +61 419 189 050
>>>>>>>> *Alex Leith*
>>>>>>>> m: +61 419 189 050
>>>>>>>> *Alex Leith*
>>>>>>>> m: +61 419 189 050
>>>>>>>> *Alex Leith*
>>>>>>>> m: +61 419 189 050
>>>>>>>> *Alex Leith*
>>>>>>>> m: +61 419 189 050
>>>>>> *Alex Leith*
>>>>>> m: +61 419 189 050
>>>> *Alex Leith*
>>>> m: +61 419 189 050
>> *Alex Leith*
>> m: +61 419 189 050
Warm Regards
Ewen Hill
URL: <http://lists.osgeo.org/pipermail/oceania-board/attachments/20240607/717125a3/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/oceania-board/attachments/20240607/717125a3/attachment-0001.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/oceania-board/attachments/20240607/717125a3/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/oceania-board/attachments/20240607/717125a3/attachment-0003.jpg>
More information about the Oceania-Board
