[OpenDroneMap-dev] Fw: [OpenDroneMap-users] Mesh Plotter for LidarLITE
Dakota Benjamin
dmb2 at clevelandmetroparks.com
Thu Nov 19 10:09:26 PST 2015
I think this is an interesting development problem space.
[http://sig.cmparks.net/cmp-ms-90x122.png]Dakota Benjamin
Geospatial Developer
clevelandmetroparks.com<http://www.clemetparks.com/>
<http://www.clemetparks.com/>"It is not down in any map; true places never are."
Herman Melville
From: OpenDroneMap-users <opendronemap-users-bounces at lists.osgeo.org> on behalf of Andrew Jawitz <andrewjawitz at gmail.com>
Sent: Thursday, November 19, 2015 11:41 AM
To: opendronemap-users at lists.osgeo.org
Subject: [OpenDroneMap-users] Mesh Plotter for LidarLITE
Hello All,
I have an update and a question regarding my ongoing experimentation with the LidarLITE...
I've been searching and searching for months for a project sample that uses the LL for 3D Mapping but apparently there were so many problems with the original i2C library in particular that hardly anyone could get it to work. Finally, I found this tutorial-
http://myrobotlab.org/content/lidar-lite-distance-measurement-and-creating-point-cloud <http://myrobotlab.org/content/lidar-lite-distance-measurement-and-creating-point-cloud>
which seems to be a good starting point. If you want a good chuckle check out the comment thread which has all of these veteran robotics guys scratching their heads trying to figure out how this guy got up and running so easily. FWIW it looks like the official documentation had just been updated to include a recommendation for this alternate i2C Library- http://www.dsscircuits.com/index.php/articles/66-arduino-i2c-master-library
Ironically it only works with the original LL (which I have) and not the updated "Blue Label" version...
Anyway, after loading the alternate i2C Library, I managed to get the sketch to compile on Arduino 1.6.6 and sure enough coordinates started popping up on the serial monitor! I can create a project gist with all the code if others would like but for now you can find the sketch I'm using on my sketchbook repo- https://github.com/Cribstone/Arduino-Sketchbook/blob/master/LidarLitePointCloud/LidarLitePointCloud.ino
If you were wondering where to find the source for the Processing Sketch referenced in the article, I was able to find it here-http://borsaci06.com/Plot_LidarScanner.pde
While, I was able to compile this sketch in Processing 3.0, it threw out a list of Java-related errors when I tried to start it(Enough to remind me why I'll go so far out of my way to avoid Java)...
So that leads to my question... Would it be possible to plot point clouds from an Arduino i2c/serial port using ODM in place of Processing?
http://cribstone.github.io/about/
URL: <http://lists.osgeo.org/pipermail/opendronemap-dev/attachments/20151119/5445dd50/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/opendronemap-dev/attachments/20151119/5445dd50/attachment.txt>
More information about the OpenDroneMap-dev
