[OpenDroneMap-users] laptop recommendation
Chris House housec01 at gmail.com
Sun Apr 12 12:25:00 PDT 2015
Look into system76 laptops. I process ~60 photos in 2.5hrs. Plenty of
process power to run ODM.   As others stated a power sources to keep charge
is going to be a must.  I have a galago ultra pro here are the specs....
Ubuntu 14.04 LTS 64 bit14.1"
1080p Full High Definition ColorPro IPS Display with Matte Surface ( 1920 x
1080 )
Intel® Iris™ Pro Graphics 5200
4th Generation Intel® Core™ i7-4750HQ Processor ( 2.0 GHz 6MB L3 Cache - 4
Cores plus Hyperthreading )
16 GB Dual Channel DDR3 SDRAM at 1600MHz - 2 X 8 GB+$175.00
240 GB Intel 730 Series Solid State Drive
No Secondary Hard Drive
Intel® Dual Band Wireless-AC 3160 AC Wireless LAN up to 433 Mbps + Bluetooth
Chris
On Apr 12, 2015 3:02 PM, <opendronemap-users-request at lists.osgeo.org> wrote:
> Send OpenDroneMap-users mailing list submissions to
>         opendronemap-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         opendronemap-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of OpenDroneMap-users digest..."
> Today's Topics:
>    1. laptop recommendation (Frederic Muller)
>    2. Re: laptop recommendation (Alex Mandel)
>    3. Re: laptop recommendation (Frederic Muller)
>    4. Re: laptop recommendation (Stephen Mather)
>    5. Re: laptop recommendation (Alex Mandel)
> Message: 1
> Date: Sun, 12 Apr 2015 19:48:49 +0700
> From: Frederic Muller <fred at cm17.com>
> To: opendronemap-users at lists.osgeo.org
> Subject: [OpenDroneMap-users] laptop recommendation
> Message-ID: <552A69B1.5060201 at cm17.com>
> Content-Type: text/plain; charset=utf-8
> Hi!
> I was thinking to add a laptop to my hexacopter which purpose is to do
> orthophoto. Do you have any recommendation regarding the CPU/RAM/HDD and
> Video for such a dedicated machine?
> What do you guys run ODM on?
> Thanks a lot.
> Fred
> Message: 2
> Date: Sun, 12 Apr 2015 10:12:59 -0700
> From: Alex Mandel <tech_dev at wildintellect.com>
> To: Frederic Muller <fred at cm17.com>,
> Subject: Re: [OpenDroneMap-users] laptop recommendation
> Message-ID: <552AA79B.6050201 at wildintellect.com>
> Content-Type: text/plain; charset=windows-1252
> On 04/12/2015 05:48 AM, Frederic Muller wrote:
> > Hi!
> > Thanks a lot.
> > Fred
> My recommendation is to not use a laptop. I'm also confused about your
> wording, you want to fly the laptop or just use the laptop to
> post-process the images. Is the reason for a laptop so you can see
> results in the field? That's unrealistic unless you subsample to a very
> small set of photos.
> A desktop, server, or virtualized server will in almost all cases
> provide faster results. In the case of virtualized you can also only pay
> a few cents an hour when you use it.
> CPU seems to matter the most right now so Intel i7 or 2600v3 cpu, solid
> state disks never hurt. At this time ODM does not appear to need huge
> amounts of RAM. It also does not yet leverage any GPU offloading, though
> there has been discussion of it.
> -Alex
> Message: 3
> Date: Mon, 13 Apr 2015 00:27:12 +0700
> Message-ID: <552AAAF0.8090505 at cm17.com>
> >> Hi!
> >> Thanks a lot.
> >> Fred
> > -Alex
> Sorry for the confusion. The "system" (read hexacopter + computer) will
> be used in a remote area with no internet access. The plan is to use
> Mission Planner for the mission planning and ODM for the image
> post-processing. A desktop does not seem the best solution in our case
> as infrastructure is very bad too (unreliable electricity sources, etc).
> We are thinking to have a casing with everything inside for easy of
> transportation and protection.
> Thanks for the other details as those will help.
> Fred
> Message: 4
> Date: Sun, 12 Apr 2015 13:44:04 -0400
> From: Stephen Mather <stephen at smathermather.com>
> Cc: opendronemap-users at lists.osgeo.org
> Message-ID:
>         <CAPkJWLUvQr7_72mLX=
> uVaXRROc3WNG7Cs4tJ196McDf_zBFHsA at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> In that case Fred,
> Go with a "Desktop Replacement" type laptop, and you'll do OK.
> Cheers,
> Best,
> Steve
> > >> Hi!
> and
> > >> Thanks a lot.
> > >> Fred
> pay
> though
> > > -Alex
> > Fred
> > OpenDroneMap-users at lists.osgeo.org
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150412/8c8fda23/attachment-0001.html
> Message: 5
> Date: Sun, 12 Apr 2015 10:53:23 -0700
> Message-ID: <552AB113.5050706 at wildintellect.com>
> >>> Hi!
> and
> >>> Thanks a lot.
> >>> Fred
> >> -Alex
> > Fred
> Unreliable power will be your biggest issue. You can get a beefed up 4
> core i7 but it will require a lot of power, at least 65W TDP (most
> laptops these days are 15W TDP). This will process ODM photos for you
> but it will still take hours depending on the number of photos. So
> unless you plan to have a generator or large external battery all of
> this is extremely tricky. Laptops with that much compute power will only
> last 1-2 hours on battery, maybe enough for 25-50 photos.
> Will you be transporting by backpack or by vehicle (does weight matter)?
> Mission planning in the field is much more realistic. Do you have to do
> the post processing in the field?
> Note with a desktop type computer you can use an external UPS to ensure
> a stable power and bridge 30 minute outages. A Well engineered desktop
> rig has much better cooling and can generally run the CPU at a higher
> clock speed, which in this case equals faster processing. Also note with
> a desktop you can get an 8 core i7, those don't exist for laptops afaik
> because of power consumption issues. Keep in mind you can use a micro
> atx case so it doesn't have to be huge.
> I currently run a 4 core i5 (3rd gen I think)  3.4Ghz turbo (turbo is
> max speed when only using 1 core) desktop . That's where I get the 2+
> hours estimate for a 25-50 photo set.
> Browsing CPUs, there's no performance 5th Gen mobile i7 yet, they are
> all designed to extend battery life over processing speed.
> 4th gen theres the MX, MQ and HQ lines
> http://ark.intel.com/products/75131/Intel-Core-i7-4900MQ-Processor-8M-Cache-up-to-3_80-GHz
> http://ark.intel.com/products/78940/Intel-Core-i7-4940MX-Processor-Extreme-Edition-8M-Cache-up-to-4_00-GHz
> Browse more cpus
> http://cpuboss.com/
> Here's an example monster laptop
> http://amzn.com/B00OBQ5QS0
> I would expect the battery to last 1-1.5 hours while processing photos
> (it has 3 hour battery if only web surfing).
> -Alex
> End of OpenDroneMap-users Digest, Vol 3, Issue 6
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150412/82670890/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
