[OpenDroneMap-users] Silver Polygons when creating Orthophoto for COPR-Dataset
Stephen Mather
stephen at smathermather.com
Wed Apr 15 16:16:05 PDT 2015
Ah, sounds like you may have had the same issue.
Cross listing with Dev list -- I'm wondering if for the test data, we
should split into datasets we know work well, and ones that are still a
challenge.
Thoughts?
Best,
Steve
On Apr 14, 2015 7:36 PM, "Alex Mandel" <tech_dev at wildintellect.com> wrote:
> Defaults. Though if you recall I got a meshlab output but not a valid
> orthophoto.
> Thanks,
> Alex
> On 04/14/2015 11:25 AM, Stephen Mather wrote:
> > It's funny, I've had trouble with COPR myself, but I know that Alex has
> > successfully run it through ODM.
> > Alex, what parameters did you use for COPR?
> > Best,
> > Steve
> > On Tue, Apr 14, 2015 at 12:44 PM, Simon <s_mailinglist at geraschs.de>
> wrote:
> >> Hello,
> >> first I want to thank all contributors for this very nice piece of code!
> >> The Points 1 - 3 are working great. I have tested two datasets so far
> >> and both pointclouds looked very nice to me without major tweaking.
> >> But I encountered a problem with the COPR-Dataset*:
> >> When I run ODM with no extra parameters, the size of the output
> >> Orthophoto is 69kb only.
> >> Run.pl exits normally.
> >> The log can be found here:
> >> http://pastebin.com/1n4CbnM9
> >> The warning for the silver polygon was printed for every face. I deleted
> >> most of these entries, for the sake of readability...
> >> Any ideas on how to solve this problem?
> >> Regards,
> >> Simon/Fi156
> >> *= https://github.com/OpenDroneMap/odm_data_copr
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150415/6dff3bcf/attachment.html>
More information about the OpenDroneMap-users
