[OpenDroneMap-users] processing undistorted Go Pro imagery
Aaron Dennis
aaron.p.dennis at gmail.com
Thu Apr 16 14:53:12 PDT 2015
Hello,
I've seen some incredible output from example datasets with OpenDroneMap.
Right now, I'm working with some researchers who fly a UAS with a GoPro
Hero 3+ Silver camera to collect video. I'm trying to pull image frames
from that video, remove the fisheye distortion, and run the images through
OpenDroneMap.
I pull frames from the video with this command:
Then, what I've been doing is removing barrel distortion (fish eye) from
the images with $ imagemagick:
convert image.jpg -distort barrel '0.030530 -0.124312 -0.038543'
I also add exif tags to the imagery using exiftool:
My challenge now is determining if 2.88 mm is still the correct exif tag
for the image, having already successfully removed distortion. Also, I'm
not sure how this will affect the sensor size in ccd_defs.json. I've tried
running the images through OpenDroneMap both distorted and undistorted
using the exif tags shown above, and each time I end up with an empty point
cloud.
Matching key points appeared to go okay.
14151 matches (23.8%) took 6.63s for
/home/ubuntu/images/reconstruction-with-image-size-2400/matches/0-1.txt
14093 matches (23.7%) took 6.93s for
/home/ubuntu/images/reconstruction-with-image-size-2400/matches/0-2.txt .
1670 matches ( 2.8%) took 6.94s for
/home/ubuntu/images/reconstruction-with-image-size-2400/matches/0-3.txt
17644 matches (28.4%) took 7.22s for
/home/ubuntu/images/reconstruction-with-image-size-2400/matches/1-2.txt .
1762 matches ( 2.8%) took 7.20s for
/home/ubuntu/images/reconstruction-with-image-size-2400/matches/1-3.txt
1901 matches ( 3.0%) took 7.18s for
/home/ubuntu/images/reconstruction-with-image-size-2400/matches/2-3.txt
But running pmvs seemed to maybe filter out all those key points? Running
meshing returned an error that the point cloud was empty.
I was wondering if anyone has a solution to processing Go Pro imagery or
video or if anyone has some ideas about what focal length or CCD size would
be appropriate for undistorted imagery.
Thanks,
Aaron
*Aaron Dennis*
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150416/35d9cbbb/attachment.html>
More information about the OpenDroneMap-users
